2000 7.3 oil leak - Ford Powerstroke Diesel Forum
post #1 of 23 Old 05-07-2013, 01:14 PM Thread Starter
7.3ford350's Avatar
Send a message via AIM to 7.3ford350
2000 7.3 oil leak
Alright guys I need some help have a bad oil leak coming from above the starter on passenger side of truck. You can start the truck and in about 30 seconds its leaking form above the starter ( like a drip every 5-7 seconds ). I have checked all my fittings on the HPOP and nothing from their but I do have a little oil in the valley but the amount is not changing.......any suggestions ???? Any idea is greatly appreciated guys. Thanks
2000 F-350 Beans diesel performance stage 1 injectors, Beans tunes 6 pos, EBPV delete, ITP boost regualtor, itp pre pump/fuel tank kit,dino fuel cross connect kit and hpx line, trans,pyro,boost and fuel presure autometer ultralite gauges, full exhaust, wicked wheel, Intake, BD Waste Gate, foil delete
2008 F-550 6.4 12ft dump
2006 F-450 6.0 12' dump
2003 F-250 5.4 gas
2006 Ford Ranger
CAT 305CCR EXCAVATOR, 289C SKIDSTEER, 257B SKIDSTEER
7.3ford350 is offline
post #2 of 23 Old 05-07-2013, 02:08 PM
russtwentyfour's Avatar
Check your turbo pedestal and plugs at the back of heads. Hope that helps
E99 F350 Ext. cab Long bed, single wheel 2x4
Riff Raff 6637 intake, FRX and HPX,
Dieselsite boostfooler, factory tech valvebody, filter system,
Local custom trans build - BTS in near future,
Derale cooling pan and trans cooler,
Mbrp 4" turbo back
Ts 6 pos chip - TW tunes coming soon,
Guzzles hutch and harpoon mod with lift pump and racor filters
Ww2
Blank pedestal with moded exhaust port
Afe rear end cover
Callahan drilled and slotted rotors front and rear
russtwentyfour is offline
post #3 of 23 Old 05-07-2013, 02:11 PM
Quoted: 31 Post(s)
The amount in the vally probably isnt changing casue its full of oil and is dripping down the back side of your motor. I had this issue (blown oring on my HPOP loosing 2 gallons every 20 miles) ended up seeping into my bellhousing saturating my clutch ruining it.
Your HPOP system has to be leaking if its only leaking while running. Mine started as a small drip like you explain and then turned into a 60 mile long oil trail untill i made it to a parts store. Glad i had a case of oil in my rig.
CarportMechanic is offline
post #4 of 23 Old 05-07-2013, 02:18 PM Thread Starter
7.3ford350's Avatar
Well all my fittings are dry (I think) around my HPOP. I am defiantly going to look at them again! Would the turbo pedestal leak only under pressure?
2003 F-250 5.4 gas
2006 Ford Ranger
post #5 of 23 Old 05-07-2013, 02:54 PM
Pedestal is part of the Pressurized oil system, low pressure but pressure non the less. If it where me I'd soak my valley, hpop and base of turbo in simple green or some sort of degreaser, get it all oil free then start from there. Be a lot easier that way to chase an oil leak than on a dirty engine.
Mbrp 4" turbo back
Ww2
Afe rear end cover
post #6 of 23 Old 05-07-2013, 03:23 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Above starter is the dipstick oring. I hate them, ask me why.
Strictly Diesel Dipstick Adapter Repair Kit
4R100, 2wd
330,000 + miles
jesilvas is offline
post #7 of 23 Old 05-07-2013, 03:49 PM
shortstrokin's Avatar
I was thinking dipstick as well except that it only happens while running
2003 F250 CCSB 4x4 6.0 Auto, 06 motor-ARP head studs, EGR delete, K&N FIPK, 4" lift
shortstrokin is offline
post #8 of 23 Old 05-07-2013, 03:49 PM
jesilvas's Avatar
Quoted: 3 Post(s)
That means it is the dipstick. The oil level is below that hole in the pan when still. When running it's slung around.
I've had mine open three or four times with oil still in it.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #9 of 23 Old 05-07-2013, 04:11 PM
Oh, I didn't know that. Always something to learn.
post #10 of 23 Old 05-08-2013, 04:07 AM Thread Starter
7.3ford350's Avatar
No not my dip stick, completely dry around there. Hopefully this afternoon I will get some time to spray it down with a degreaser and start from their.
2003 F-250 5.4 gas
2006 Ford Ranger
