7.3 loud knocking - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-01-2013, 02:54 PM Thread Starter
Send a message via AIM to zach7.3young
7.3 loud knocking
Hey I'm new to this forum and trying to get used to it so bear with me please!😁 I've got a 99 7.3 powerstroke with 246k miles and it recently started leaking anti freeze and it has a loud knock when idling. I've brought it to ford and they said head gasket for the leaking anti freeze and a bent rod in the bottom end for the knock without putting it on the computer..... They also said with the bent rod I might as well be better off with a new motor! I'm trying to get other people's opinion before I sink tons of money in my play toy! Thanks
zach7.3young is offline
post #2 of 4 Old 05-01-2013, 03:09 PM
Gene's Avatar
Quoted: 3 Post(s)
Hello.
Neither of those diagnostics would be found with the computer. What were you doing when the noise started? How much boost were you pushing?
A blown head gasket could cause the antifreeze leak. It would take quite a bit to bend a connecting rod. I would more guess a push rod.
Good luck,
Gene
2001 F350 Crew Cab Long Bed 4x4 6 speed
PHP Hydra, 4 inch MBRP Exhaust, GTP38R, FRx, DIY Exhaust Brake, T500 HPOP, Hutch/Harpoon,
6-liter Intercooler, 6637, DIY Coolant Filter, CCV Mod
Gene is offline
post #3 of 4 Old 05-01-2013, 03:31 PM Thread Starter
I'm not sure what I was doing when the knock started it just kind of started and ive heard people say sometimes when an injector is out it makes a knocking noise
post #4 of 4 Old 05-03-2013, 08:02 PM
Gene's Avatar
Quoted: 3 Post(s)
I've heard some people saying that injectors can knock, too. But I've never heard one knock.
I don't know how you treat your truck, but an antifreeze leak and a bottom end knock does not sound like something small. Head gaskets don't normally blow on a 7.3, but can if you hammer on it long enough.
Please fill out your signature block with your truck info to give people an idea of what you drive.
Oh, and
Gene
Gene is offline
Tags
7.3 , f250 motor problems , powerstroke
