Won't start/stall - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-01-2013, 06:22 AM Thread Starter
Won't start/stall
On an early '99 7.3. Had brake work done by a local tech. When I went to pick it up, it wouldn't start. We tried starter fluid. It would run on the fluid but not stay running. I suggested the cps. Instead, he left it on a trickler overnight and it started right up. When I drove it home, it stalled out a few times. Each time I could immediately start it up. Yesterday, I want to start it up, and, no joy. So I replaced the cps, still nothing. So I checked all the fuses in the engine bay. The only blown one was a 7.5, so I swapped it out. Nothing. I have noticed that the "wait" light/glow plug light isn't coming on. I thought that was due to the cps. FWIW, the new cps is a Ford part, not aftermarket.
Any ideas!??!! TIA!!!!
markwemple is offline
post #2 of 5 Old 05-01-2013, 06:27 AM Thread Starter
I should mention that before this, only in really cold weather did she need to be plugged in and would start on the first turn every time as long as I gave her a good glow. She performed flawlessly on a trip from NY to MD recently. And, she has about 210K on the clock.
post #3 of 5 Old 05-01-2013, 10:48 AM Thread Starter
Please let me know if you need more info. Really need help on this.
post #4 of 5 Old 05-02-2013, 09:36 AM Thread Starter
We have a winner, on another board. PCM fuse! Really, the PO wires up the plow through this fuse, and it had worked itself loose. Have to configure something better.
post #5 of 5 Old 05-02-2013, 05:00 PM
Jakeman711's Avatar
Great that you found the problem, but NEVER use staring fluid on these engines. Ether is one of the few things that will destroy a 7.3 PS. You might be ok because your PCM didn't kick on the glow plugs, but using ether is a good way to crack a ring. You might want to find a new mechanic, and I'm not trying to be mean.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
