Studdering around 1800 rmps - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-29-2013, 02:09 PM Thread Starter
since ive owned my truck everytime i would turn on my wipers my truck would studder...My truck threw an cam position sensor code so i replaced it. then the wierd studder at 1800 rpms became constent. it threw another code so i cleaned my ebp tube and replaced the sensor. studdering still there...is it a possibility that i got a bad new cam position sensor? everything is hooked up and reconnected just like how i took it all apart...anyone have any suggestions before i burn my truck to the ground and file an insurance claim...im pulling my hair out over here!!!
ace18788 is offline
post #2 of 6 Old 04-29-2013, 02:45 PM
This may not help but I've got this surging issue going on that's intermittent. I've been told its the ICP sensor which might be what you have going on. Also, get the CPS from Ford the aftermarket ones have been known to have issues. I hope that helps.
97 F350 CC LB 118K Stock, DIY 6637 intake
97ygh is offline
post #3 of 6 Old 04-29-2013, 02:59 PM Thread Starter
any free advice is good advice right now. thanks!!
i also need to add that all the codes are off and cleared and none are popping up...maybe i need to put some more miles on it?
I checked the ICP and there was oil on the connecter...so i guess ill replace that one too...this truck is making me more broke everytime i pop the hood. i guess if ya wanna play ya gotta pay!
ace18788 is offline
post #4 of 6 Old 04-29-2013, 03:36 PM
One other thing to check is the tps (throttle positioning sensor). I've checked all these on mine and it still has the studdering/surging issue which is really *#*# me off. But it might be the cure for yours.
97ygh is offline
post #5 of 6 Old 04-29-2013, 04:01 PM
Ya I didn't see that on your last reply if the ICP sensor has oil in the connector than its bad or going bad. Let me know if it cures for you. And yes I to have been dropping $$ every time I pop the hood.
97ygh is offline
post #6 of 6 Old 04-29-2013, 06:52 PM Thread Starter
i sure will and thanks again...ill be getting everything hopefully by this weekend.
ace18788 is offline
