Help! Not just another fuel leak thread. At a loss. - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-29-2013, 10:55 AM Thread Starter
travisj1987's Avatar
Exclamation Help! Not just another fuel leak thread. At a loss.
Alright im going to start off with what i have.
2000 f250 7.3 4x4. Pretty much stock ive cut the mufler and a intake and little things like that but no fuel system upgrades or anything crazy.
My issue started a few months ago when i noticed that my truck was leaking. So i started down the road of trying to figure out what was leaking.
Here is what i know, it is leaking from the water fuel sperator/filter on top of the block. Classic running down the back into the vally and running down the drain.
I have already done a complete rebuild minus the FPR on the housing, used the kit from diesel o-rings. So all the seals should be good.
Here is what i dont understand. It didnt leak for about 1000-1500 miles. The valey was drier than it ever has been. I go into town the morning and it starts pooring. Its done this before were it will appear to be fixed and then leak like crazy. It is leaking between the cap and housing. so i thought ok maybe its a bad/wrong seal or cap. They were the last things that i replaced...
Long story short its leaking between the cap and houseing and all the seals have been replaced, It was good and was not leaking a drop for a few months untill it started leaking again. im at a loss. I dont understand why it would be so spiratic and all that. Any thoughts or ideas would be greatly appreciated.
2000 f250 7.3 4in straight pipe,diy intake, zoodad mod,heavy duty torque converter, shift kit, warn premium locking hubs,isspro gauge kit(trany temp,egt,boost)<--awesome kit
. ext cab long bed 4x4 PHP 6 pos chip
travisj1987 is offline
post #2 of 4 Old 04-29-2013, 01:27 PM
t-ray-4ray's Avatar
Quoted: 79 Post(s)
The cap could have not sealed good and the gasket pushed out due to fuel swelling it I have had that happen try a new cap and oring gasket
Sent from AutoGuide.com App
2000 f-350 4x4 extended cab, went from a flatbed work truck to what you see now, all done by me. Early 99 engine, billet low stall converter, rebuilt trans, all new uvch, new belt tensioners and idler pulley, rebuilt injectors, all new icp, idm, cps, hutch mod, k&n intake, white valve covers, wicked wheel, 5 inch exhaust, php hydra chip 15pos, 8" superlift, 20 inch black and machined rims, 2" billet spacers, 37/13.50r20 toyo open country tires, rough country dual stabilizer, 05 front end with 10k hid lights, amber led cab lights, 09 ford van bucket seats, 2010 f150 center console, b&m ratchet shifter, aero force scan gauge, b&m trans cooler used as a fuel cooler,
t-ray-4ray is offline
post #3 of 4 Old 04-29-2013, 04:55 PM Thread Starter
yeah, apparently after market caps and filters are more likely to have this issue. I went back to motorcraft so hopefully itll be fixed. The only other thing i can think it is is something to do with fuel pressure. Im at a loss
post #4 of 4 Old 04-29-2013, 06:14 PM
t-ray-4ray's Avatar
Quoted: 79 Post(s)
I had the same problem from using cheap filters and caps the oring swells front the fuel and if not seated correctly it will leak randomly. I did a hutch mod and have a spin on filter under my truck and I use Donaldson fuel filters that we use on all our peterbilts I just let the costly ford filter go unchanged for one year and it still looked new like I jut put it in due to having the spin on filter before the fuel pump it's probly the best mod you can do to these trucks as far as the fuel system goes
