Getting ready to pull the motor on the 7.3 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 04-29-2013, 02:08 AM Thread Starter
I removed the whole front clip, everything on the motor is disconnected besides the fuel lines (didn't have the quick disconnect tool on hand) and the trans bolts are still in. Is there anything i should know and check before continuing? or something to watch out for? Reason I am pulling it out is so i can do the oil pan seal and the turbo. I just don't want to run into anything and screw myself over.
StrokinThanCummin is offline
post #2 of 9 Old 04-29-2013, 02:56 AM
Nothing is too surprising at this point. It's a lot easier to wiggle it out if you remove the turbo and take off the oil filter.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #3 of 9 Old 04-29-2013, 07:56 PM Thread Starter
Was hoping to do the turbo when it was out of the truck haha, just seems like a ***** to get my big hands back in there and what not.
post #4 of 9 Old 04-29-2013, 09:16 PM Thread Starter
Also, I was curious to what you guys think i should do. Almost everything from the hood down and a few feet back is soaked in oil sludge. My buddy who is helping me pull the motor says I should leave it, would help reduce rust haha. It's not a show truck or anything. Just a work truck with a few power upgrades. Think I should degrease it or leave it?
post #5 of 9 Old 05-01-2013, 02:57 PM
i would absolutely degrease it if its coming out of the truck, you'll never get a better shot at it then now. Also it will help identify future oil/fuel leaks if any. Didn't want to cut the crossmember ay?
02 F250 7.3 Ext. Cab Long Bed
6637 DIY intake, muffler delete, EBPV delete, 6.0 cooler, ISSPRO gauges
285/75/16 BFG a/t's
lakailimited06 is offline
post #6 of 9 Old 05-01-2013, 09:12 PM Thread Starter
No way lol. Besides the turbo and pedistal need to be replaced anyways. Would be alot easier with the motor out.
post #7 of 9 Old 05-03-2013, 06:34 AM
timmyboy76's Avatar
with motor out, inspect the uppipe connections.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #8 of 9 Old 05-03-2013, 08:16 AM Thread Starter
That is what someone told me before.... Wth is a uppipe?
post #9 of 9 Old 05-03-2013, 02:09 PM
Jakeman711's Avatar
They are the two pipes that come off of the exhaust manifolds and connect to the turbo collector. Also, you are going to have a hell of a time (you can't lift the engine high enough for the oil pan to clear the crossmember) getting the engine in and out without removing the turbo. The turbo comes out pretty easily.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
