wastegate actuator is bad??? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-28-2013, 04:47 PM Thread Starter
Is it possible for the stock actuator to go bad? Maybe get weak and not hold boost? I followed the adjustment procedure and have it set to 10 psi. It says 5 psi but I figured it might hold better with 10. I'm not sure. I only can get 10 psi of boost and the actuator is my last resort.
2000 f250 single cab long bed, 7.3, rebuilt stock turbo, XDP fuel regulator, injector harness mod, 17 inch pro comp extreme wheels, 33 inch dynapro tires, 5 inch mbrp exhaust, autometer boost gauge
dieselyoungster114 is offline
post #2 of 2 Old 05-03-2013, 04:38 PM
Jakeman711's Avatar
As with any mechanical part failure is always an option.Take the line off the acutator and go for a spin. This should keep it closed and you should build boost beause it will not open. If this is the case get a new actuator. I don't run one on my truck becuase I put a van turbo on it, but the van turbo has a larger exhaust housing so over boosting is not as much of an issue.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
