Contribution test question - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-27-2013, 07:25 PM Thread Starter
I hog a misfire under load no codes but every time I did a cct I got different results #2 cylinder replaced injector did test again #6 cylinder replaced that injector did test again #5 cylinder so I replaced that injector now I did it again all test pass and no codes I have a misfire under load and a bad misfire at 2500rpm at wot need help badly
Replaced :
PCM
Valve cover gaskets with harness
Fuel pump
Fuel tank screens and pickup
Glow plugs
Ohmed wires from idm plug to valve cover
#2,6,5 injectors replaced
Anthony239 is offline
