Low Boost Help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-27-2013, 03:50 PM Thread Starter
Low Boost Help
I posted in the general area because I thought it might be my chip taking a dump. After doing a bit of research I don't think its the chip.
my truck is an 02 7.3 has a Superchip Gold Bar (2003) 80hp/100lbs torque. I have a 5" exhaust and a sealed Volant intake system.
Truck was running just perfy and then yesterday I went to drive it and I have no power. My boost only gets up to 8-9 lbs. I have checked my plumbing and don't see any air leaks either. The truck runs fine just no power. If I floor it builds to only 8-9lbs of boost and that's it. Prior to this I could hit 28lbs. It feels stock sorta.
Any suggestions what I should look for next? Could it be the wastegate, MAP sensor...Pictures would help too!Lost here
2002 F250 7.3 PSD Crew Cab.
4" Borla exhaust with 5" tip
Airaid intake
BullyDog 6 Position 4 Bank Chip
AutoMeter Pyro & Boost on pilar
Nothing better than seeing the look on the face of the kid driving the Mustang thru my rear view mirror.
Dang I just got creamed by a truck
Scooterdog is offline
post #2 of 5 Old 05-05-2013, 07:46 PM
Mikestime22's Avatar
I'm having the same issue. Too bad no one has made any suggestions, it would be helpful.
Mikestime22 is offline
post #3 of 5 Old 05-09-2013, 08:35 PM
Jakeman711's Avatar
Well, did you check your up pipes? For it to just start happening out of the blue is strange. Double check all of your CAC boots. Tears can happen on the bottom of these boots where they are not easily seen. Make sure that the boots that hold the intake spyder to the intake pleanums on the head are tight and not torn. You are loosing boost somewhere. I know it is a no brainer, but is your air filter clean? Please let us know what you find after taking another look.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #4 of 5 Old 06-25-2013, 03:36 PM
jesilvas's Avatar
Quoted: 3 Post(s)
Where are you getting your boost reading? MAP or a mechanical gauge with a tap?
You won't see any air leaks. It's air.
You need to pressure check.
Then could be exhaust leak. EBPV closing for some reason. WG actuator weak and dumping exhaust past the turbine.
Low fuel pressure, lack of high pressure oil, PCM fueling.
It can keep going.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 5 Old 06-25-2013, 04:10 PM
jesilvas's Avatar
Quoted: 3 Post(s)
The OP's issue?
4R100, 2wd
330,000 + miles
jesilvas is offline
