All injector sleeves replaced but seeing some diesel in coolant - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-27-2013, 04:24 PM Thread Starter
73watermutt's Avatar
Hi, I have a 2002 7.3l powerstroke with 172,000 miles and just had all the injector sleeves replaced and the radiator flushed. I'm still seeing and smelling diesel in the coolant tank. Also a very tiny bit of black film. The repair is only about a week old and it was done by a Ford dealership. Is this normal after this type of repair and do I need to have it flushed again? Any help would be greatly appreciated. The truck is running great by the way but this is bugging me and I don't want to screw it up.
73watermutt is offline
post #2 of 7 Old 04-28-2013, 09:45 AM Thread Starter
Thinking it may just be residule and needs flushed again.
post #3 of 7 Old 04-28-2013, 11:22 AM
JamieSinns's Avatar
probably need to hotwash it as the diesel is oil based and must have heat to help "cut" the oily substances. you're right, seems like residual.
JamieSinns is offline
post #4 of 7 Old 04-29-2013, 06:47 AM
Give it a week or so, but cups are finicky at best, the area has to be so clean when they're installed and its extremely frustrating.
2001 F350 7.3L.
349459KM on original motor.
Just rebuilt my 4R100.
Mods are simple....4" custom turbo back exhaust, stage 2 AFe CAI, Edge CTS Tuner, HID Lights, much more to come.
Use my rig for Work, If you need electrical, or electrical advice, don't hesitate to ask.
L0sts0ul is offline
post #5 of 7 Old 04-29-2013, 08:54 AM Thread Starter
I have only put about 20 or so miles on it since the repair. Will it cause issues to drive it like this? Should I drain the coolant and put new in before driving? Sorry for all the questions but I don't want to screw something up.
post #6 of 7 Old 04-29-2013, 03:58 PM Thread Starter
I drove it into town and back today about a 20 mile round trip. I noticed when I got home that the coolant level is well above the max fill line and it was just a fuzz under before I started it. It looks like it was leaking a bit out around the cap and down the back side of the coolant tank. I can see a small hole on the lip around the filler neck that it looks to be coming from. I'm starting to worry that I bought a problem. I just bought this truck a week ago and the dealer did all the work before we looked at it.
post #7 of 7 Old 05-06-2013, 06:28 PM
Don't know if you got the problem solved, but 02 was doing the same thing and it was the oil cooler bad o rings letting oil into anti freeze.
rossronald is offline
