Smoking - Ford Powerstroke Diesel Forum
Old 02-17-2008, 09:31 AM
Smoking
Have a slight smoking problem. After driving on the freeway and getting off onto regular roads my truck bogs down and white smoke comes out of the exhaust. It does it more so after stopping at a red light. It also does this after going down a long hill, coast down the hill and when reaching the bottom I push the accelerator to maintain speed and it bogs and blows white smoke out. What would cause this? It does it with the ebpv plugged in and unplugged. I have a new fuel filter and the oil and oil filter are new. I dont get any check engine lights or anything like that.
Thanks for the help
Old 02-17-2008, 09:48 AM
Desert Shield/Storm Vet
How many miles on the truck?
Old 02-17-2008, 11:51 AM
312k miles on it
Old 02-17-2008, 03:07 PM
Well could be quite a few things. When is the last time the fuel filter has been changed? I would start with that and possibly a fuel pressure test.
Old 02-17-2008, 03:11 PM
I gave you some bad advice since its white smoke sorry had a brain fart. Probobly with that many miles I would check for any codes get it scanned for codes and go from there, but you probobly need an injector buzz test and probobly a cylinder contribution test. Will need to take it to someone who can perform those tests with a scan tool.
Old 02-17-2008, 03:12 PM
International Threat
Where are you located?
Welcome to the site.
Old 02-17-2008, 03:25 PM
Thanks guys. The fuel filter was changed two weeks ago. Im in columbus ohio. What kind of scanner would you recomend to get, or do I have to take this to the dealer to get it scanned? Its been doing this for a little while but here lately its been getting a little worse. Doesnt really matter what the temperature is outside. And am I able to do the buzz test and contribution tests on my own? Thanks again.
Old 02-17-2008, 03:37 PM
You could if you had a scanner that will perform those tests. They are high dollar items. The cheapest one would be auto enginuity that runs on a laptop. I would take it to someone you trust. Is your truck stock? Do you have access to a programmer that will scan a powerstroke? If you do you could start there to see if you have any codes. My guess is with that many miles you have some worn rings.
Old 02-17-2008, 03:48 PM
your not to awful far from me and i have access to a snapon scanner that will do all that im bout 50mins from cols id be happy to give you a hand on a weekend sometime if the distance or weekends arent good theres columbus diesel service theyre not bad and theyre close but my preference for things i dont tackle myself is purrformace diesel thats not a mis type that how they spell it theyre in fredricktown just outside of mt vernon and are about the best in the area
Old 02-17-2008, 04:24 PM
My glow plugs need changed so I guess Ill run a compression test while they are out to see if its down. And I know where columbus diesel is so I may stop by there but thanks for the offer.
