Misfire with light white smoke with black smoke need help please!!! - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-24-2013, 03:42 AM Thread Starter
Misfire with light white smoke with black smoke need help please!!!FIXED PROBLEM
Hi I'm new to the forum I posted a thread a couple of weeks ago my problem got worse I have a constant misfire with white smoke at aceleration with black smoke too also when warmed up can drive but hesitates at wot the trucks a late model 99 with 75000 on motor things ive done I've ohm the wire harness from idm to valve covers replaced both valve covers and harness/fuel pump/fuel filter/two injectors on driver side/two pcms/cleaned exhaust pressure tube/two CPs/4 glow plugs on driver side/cleaned screens in fuel tank/replaced pickup in tank/ also pulled oil fill constant stream of smoke coming out. Ill have ae scanner in one day to post any codes or test any suggesting this is my daily driver it's been down for two months thanks guys
Ok got scan tool today
All test good except got a code po476 exhaust pressure control valve range / performance
Also did icp readings at idle 480 and WOT AT 60mph 2750psi
Also exhaust pressure at 18 on idle and wot 20-24
Hope this helps thanks guys
Anthony239 is offline
post #2 of 6 Old 04-25-2013, 07:02 PM Thread Starter
Newest update for y'all I got po275 code when doing contribution test could this be a injector going bad?
post #3 of 6 Old 05-13-2013, 08:42 PM
dieselhate's Avatar
same problem here.....
so my truck went out on me the other day. i sat in a parking lot for two hours messing with it before i broke down and called a tow truck. then while i was at work a "friend" helped me out and changed the fuel pump. well before he changed the pump he HAD to make sure i was right (even though he was told i know what im doing. disconnected fuel lines from pump, checked fuses, etc.) )he ran a solus pro diag. on it and came up with a bad cps. so he went to a store and BOUGHT a CPS. this is a long time mechanic, mind you. if you know what i mean, you know what i mean. h so he started spraying a bunch of ether in my freakin intake while its getting NO FUEL. he says to me "well,i got it running but it seems like you need new injectors." right then i guessed what happened. so yes, i started the truck and i heard and felt several misfires. i drove the truck and it misfired and my once-gray-smoke-producing truck now fires grayish white and black and misfires to high heaven. i really need an expert opinion, im worried about this i just got this truck a few months ago and barely started paying for it!! is it possible that its not something devastating and something simple? could a fuel pump thats shot cause another problem instantly to some other system within a few minutes of it failing? maybe cause a problem with the ipr? or hpop?
dieselhate is offline
post #4 of 6 Old 05-15-2013, 02:02 AM Thread Starter
I ended up fixing mine it turned out to be a CPs that I bought from advance auto parts my truck doesn't like part store CPs I got one from ford fixed my my misfire you gotta remember it controls fuel also but my surge was the ebp sensor was cloged. But those two things fixed everything I hope this can help you dieselhate.
post #5 of 6 Old 05-18-2013, 06:58 AM
did you happen to notice if you had a considerable amount of smoke coming out of your oil fill cap before you fixed the problem? My truck is acting exactly the same but it failed the oil cap test. Also very hard to start.
abogle is offline
post #6 of 6 Old 05-21-2013, 03:35 AM Thread Starter
Abogle
It was a constant steam like smoke very lite like if you have a thick stream of smoke I would do a compression check if you haven't already
