Fuel filter change issues - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-22-2013, 03:04 PM Thread Starter
This is the 2nd time i have had issues changing the fuel filter, What am i doing wrong? Changed the filter sunday did the key cycle like 20 times fired up no issues 2 hours later started to leave then is was like she was out of fuel again cycled the key then started drove to work no problems came home from work no issues. Then again today issues WTH will not fire? the fuel guage shows just under 1/4 tank also i changed the filter again NAPA gold filter still no change. Any help?
fomoco is offline
post #2 of 4 Old 04-22-2013, 03:16 PM
Quoted: 13 Post(s)
Might be time to drop the fuel tank and make some repairs to the pickup tube.
There are some mods that address the fuel tank and lines.
Check this out.
http://www.guzzle7pt3.com/hutch.php
Dave
02 F350 CCLB Lariat 4x4 auto
230,000 on the clock
dieselsite trans filter,
dieselsite coolant filter,
6637 filter
Stancor GPR
6.0 tranny cooler
4" Diamond Eye K4318S-RP exhaust
riffraff regulated return
dual alt.style upper rad. hose
05-07 head light mod
PHP Hydra
Alliant Power 160 single shots
WW2
HPOP system cross over hose from Corey
3 gauge A pillar gauge pod with EGT, trans temp and boost gauges. Autometer ford matched gauges.
glow plug light installed in gauge pod.
welove2drive is offline
post #3 of 4 Old 04-22-2013, 06:53 PM Thread Starter
Thanks dave.
fomoco is offline
post #4 of 4 Old 04-22-2013, 08:07 PM
Quoted: 13 Post(s)
Do some more asking and checking. From what I have read there is a possible problem with the pick up line in the tank which brought up the Hutch mod idea but I have not had this problem yet. I'm not sure if there are any check valves in this fuel system which could be letting the fuel drain back or not. Plenty of guys here know a lot more about it then I do. Hope you can track down the problem.
Dave
6637 filter
Stancor GPR
6.0 tranny cooler
PHP Hydra
WW2
