Cam and crank shaft position sensors - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-19-2013, 04:40 PM Thread Starter
Went to ford to pick up a new crankshaft and camshaft position sensors. Oddly, they were out, but the parts tech stated that they are the same sensor and are interchangeable. Is this true? I've never heard that before with any of my other cars in the past, but if it is it would be handy to know.
1999 F350 Lariat CCLB DRW
No known mods
GM.Chief is offline
post #2 of 4 Old 04-19-2013, 05:24 PM
Yes there is only one sensor on these. It's at about 11 o clock above the harmonic balancer on the front of the motor. It's called the CPS on here but I don't know for sure if that C is for cam or crank. I've heard it both ways and they both mean the same sensor.
Sent from AutoGuide.com App
2001 F350 SRW CC 4WD LB
ZF6 w/ Southbend, 220k, DIY Intake, WW,NonEBPV Pedestal, CCV Mod, Gauges (Boost, Pyro), 2in Leveling Kit, 4" Straight MBRP, AIH Delete, 2-12" Kicker Comp's, Pioneer Amps
2001 F350 DRW EC 2WD (Rolled Over)
2000 F550 CC 2WD
Automatic, Jasper 4R100 w/Derale Pan & 6.0 Cooler, DIY Intake, AIH Delete, 4" MBRP,
Schnot is offline
post #3 of 4 Old 04-20-2013, 05:24 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
It's obviously just where you put it!
Here's the thing, along comes OBD and they have to standardize the nomenclature so everybody's on the same page. CPS stands for Camshaft Position Sensor (my STS has 4!) but, Cam or Crank, they do the same thing. So, for Us, it's a Crankshaft Position Sensor because that's where it doin' its sensin'
NoRalPh is offline
post #4 of 4 Old 04-20-2013, 06:47 AM Thread Starter
Alright, so the 7.3's only have the one sensor. I see. Heck, our minivan had two separate sensors. Guess I figured the big diesel would too. Lol. Thank you for your help guys.
No known mods
GM.Chief is offline
