7.3 starting problem - Ford Powerstroke Diesel Forum
Old 02-13-2008, 02:08 PM
grc grc is offline
Exclamation 7.3 starting problem
hey yall.. I was hoping yall could help me out. i got a 02 f250 with a 7.3 and its runs perfect but every once and awhile ill kill it and go into the store or whatever. . When i try to start it it will not start. It will crank strong but no fire... like it was starving for fuel... but i figured if that was the case then why would i not have problems out on the road... thanks
Old 02-13-2008, 02:22 PM
If it aint a CAT itsa DOG
It could be the cam position sensor going out. Does the tach move when you crank on it? If the tach doesn't move you need a CPS. You could try a new fuel filter as well. Ford issued a recall on the CPS so you could call your local dealer and ask them if they will cover your truck.
Old 02-13-2008, 02:27 PM
Powerstroke Techie
I have heard that a no start only when hot can be caused by the IPR valve, I think, if it were me, I would try my spare cam sensor first and then take a look at the IPR (injector pressure regulator).
Old 02-13-2008, 02:31 PM
Desert Shield/Storm Vet
Just for your info that trick doesn't work on 02's and newer
Old 02-13-2008, 02:37 PM
ill second the ipr
Old 02-13-2008, 02:50 PM
Ahhh, i've never heard of that before. You learn something everyday. Is that because of the new style dash?
Old 02-13-2008, 03:03 PM
I can't remember off the top of my head. Somthing to do with the pcm
Old 02-13-2008, 03:07 PM
Powerstroke Techie
I keep a spare CPS anyways, heck for $20 why not keep a spare, for the 5 minutes it takes to change it I say swap it if there is any doubt.
Also you probably can replace the IPR O-rings much cheaper than you can replace the IPR.
Old 02-13-2008, 03:49 PM
grc grc is offline
thanks yall
