i have a 96 f-250 psd. my truck keeps blowing the #22 fuse. any ideas on what it is?
Yeah thats your fuse for the fuel heater element. You have to unplug the fuel heater at the fuel bowl as its shorting out.
i'm new to the diesels. could you give me a little walkthrough so i will know what i'm looking for?
You bet. Under the plastic engine cover is the fuel filter bowl it will have a black round plastic cover. Inside that bowl is your fuel filter and a heating element at the bottom. Its a poor design and this is common. On the drivers side about 3/4 of the way down inside the bowl there is a wire with a blade connectore unplug it.
If your in a cold climate you will need to replace the element. Otherwise if you live in a warm part of the country don't worry about it
and it's only doing it if the temps gets below about 50. the last time it did it i replaced the fuse then it started right up. it did it again today and i replaced the fuse and it immediatly blew it. i'm goin to colorado on saturday and i would like to get it sorted out before i get there. should i plug it in everynight or what?
Plugging it in won't help with your fuel. If you going to be in cold temps which you will be get to ford or international and get a new element put in before you go or you might have some gelling issues or at the very least the wax in the fuel plugging your fuel filter.
i guess that was it. i pulled the element, replaced the plug and it started. thanks
You bet
i mean fuse
