replacing oil pan/gasket - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 23 Old 04-17-2013, 04:59 PM Thread Starter
Trucks been leaking at the pan right in the corner by the starter. Cleaned it up, removed inspection plate, made sure the truck was hot/running and finally confirmed its coming from the oil pan gasket and not the rear main.
Since im doing the crossmember cut/weld due to costs/downtime what else should i replace while under there? Im getting a new pan from Ford, gasket maker, dipstick tube, dipstick flange unless the pan comes with one already. Also going to cover the new pan in some type of corrosion resistant paint etc while its out..
Thanks
Jason
02 F250 7.3 Ext. Cab Long Bed
6637 DIY intake, muffler delete, EBPV delete, 6.0 cooler, ISSPRO gauges
285/75/16 BFG a/t's
lakailimited06 is offline
post #2 of 23 Old 04-18-2013, 12:09 PM
Quoted: 143 Post(s)
Feedback Score: 3 reviews
Do you already have the Bloody Apron you'll be wearing or, do you have to go get one First?
NoRalPh is offline
post #3 of 23 Old 04-18-2013, 02:45 PM Thread Starter
i dont follow?
285/75/16 BFG a/t's
post #4 of 23 Old 04-18-2013, 04:40 PM
Quoted: 143 Post(s)
Only a BUTCHER would cut out the crossmember....
You know the reason Ford has you pull the motor is so you get a proper reseal of the pan. The oil that runs-down the inside walls, when the engine is Not inverted as it's supposed to be, will contaminate the gasket sealer
NoRalPh is offline
post #5 of 23 Old 04-18-2013, 05:12 PM
sprksonu's Avatar
i agree you only will be wasting your time and money you will never get a correct seal and will probly leak a lot more the way you are planning on doing it
WRECKED EM DAMN NEAR KILLED EM!
2005 f250 ccsb 4x4 Studded, 03 turbo w/billet wheel, AFE stage2, 5"diamond eye, BPD egr cooler & "NEW" external oil cooler, BPD 48v FICM, BPD water pump, BPD aluminum radiator, 6.4 banjo's, blue spring, HFCM e-z drain, riff raff boots, gearhead srl tune , PHP FICM tune, sct livewire 5015, updated stc, updated stand pipes & dummy plugs, updated oil feed & drain, Zerex ELC coolant, Pro Comp 6" lift, 325/70/17 Toyo open country at
sprksonu is offline
post #6 of 23 Old 04-19-2013, 07:16 AM
Quoted: 143 Post(s)
PLUS, the cross member will never go back "right". From a Geometry aspect, metallurgical, corrosion, strength, it will Always be a Butchered Truck.
How will the top side ever be rewelded right with the motor in place? You can't get a Mig gun in there, a Tig torch, only thing I could think would be a "blob-job" with Stick welding...
What an "F"ed-Up thing to do
NoRalPh is offline
post #7 of 23 Old 04-19-2013, 07:45 AM
justinlogue5_0's Avatar
You will have to let it drip dry for at least a week to avoid contaminating it and getting a good clean dry seal , that part I agree with. The cross member howerver, another guy on here did just that and has had no issues. He welded up some nice gussets and actually bolted the cross member back together incase he ever had to pull it out again. Wish I could find that thread now.
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #8 of 23 Old 04-19-2013, 11:46 AM
I have installed the oil pan with motor in the truck on a international 4700 series truck before. I dont think you will have a problem there. Just make sure to put a good 1/4" bead on the pan gasket and let it sit over night before you start the truck.
Cutting the crossmember dousnt sound to good, but if you have a shop with some good welding / cutting tools I am sure you will be able to reinstall the member good enough. my 2 cents
barrakudaman is offline
post #9 of 23 Old 04-19-2013, 02:08 PM
Quoted: 143 Post(s)
Originally Posted by justinlogue5_0 View Post
The cross member however, another guy on here did just that and has had no issues. He welded up some nice gussets and actually bolted the cross member back together in case he ever had to pull it out again. Wish I could find that thread now.
Didn't say it couldn't be done,,, just that it couldn't be done right
If you went to buy a truck, slid under and saw that, would you go through with it? I mean, and I'm telling you this, it's screwed-up the frame geometry. It just has to, all that weight still in place and Something is gonna shift. Once welded, in it's new position, you're stuck like that.
Any WHY???? How much time could actually be saved? (this isn't an easy thing to Do & UnDo). How LAZY can you get with something this important? You've made it weaker, it's gonna start to corrode inside, all to save a couple of hours work? Anyone would have to ask - If he's willing to "rig" THIS, what other shortcuts can't I see????
It's a foolish move....
NoRalPh is offline
post #10 of 23 Old 04-19-2013, 04:42 PM Thread Starter
i work at a marina and have a full shop/tools/220v mig to work with.
I agree 100% it is not the correct way to go about it, however i don't believe it can be considered a "butcher job" without seeing the finished job.
After reading a few threads about the subject, i too agree the crossmember provides little support if any to the vehicle. It does have a huge hole in it to begin with and that is right where i'd be cutting, just enough to clear the oil pan.
I am also more than confident in my welding abilities to make this thing stronger then it was when im finished. I do plan on adding addition 1/4" plate to support it, not just butt welding the joints where i am cutting.
From my experience, the more you take apart the more chances you end up messing up something else and i cannot afford the down time this is my daily commuter/work truck. I would be fine with pulling the motor if I had a week off from work, but my only window of opportunity is possibly a saturday and sunday.
I do plan on letting the oil drain for awhile and being very thorough with getting a proper seal, but i think some people on here tend to make a bigger deal about that than it really is. When you service your differentials with Permatex Ultra Black you can add oil withing 20 minutes of setting the cover and be absolutely fine. However i do plan on letting it set longer only because of the amount of work involved.
Also im keeping this truck for quite sometime, hence the reason trying to get this solved ASAP. I would never sell it to someone without letting them know the work i've done to it, i would never want to see someone get hurt.
Jason
285/75/16 BFG a/t's
