2000 7.3 powerstroke, 218000 miles, remanufactured ad injectors from swamps diesel less than 1200 miles ago, new uvc wiring harness and vc gaskets, fuel filter, and glow plugs. shes been smoking a lot at cold start, white, then blue, then it continues to blow light blue smoke until you've been driving for awhile.. in the past 1200 miles ive burned roughly 2 quarts of oil, theres a small drip coming from the oil plug, but not enough to have lost 2 qts worth... where should I start? I also did the 6637 mod but not the ccv mod, my intake is a little oily, but not bad.
check the fuel filter housing for oil. if so your o-rings on injectors have failed. My truck has failed orings right now.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
