Hard starting - Ford Powerstroke Diesel Forum
Old 02-10-2008, 08:19 PM
PMR = JUNK
Hard starting
I've been a member here for a while, but ive just been lurking in the shadows, but anyway, lately my 7.3 has been starting a bit harder than when i first got it, it just seems to take a bit more cranking before it fires. What could be causing it to do that?
Old 02-10-2008, 08:22 PM
Desert Shield/Storm Vet
Could be your glow plugs or the relay weak batteries etc. Plug your truck in tomorrow night and then try starting it. If it starts better then I would next check your relay and glow plugs and then go from there.
Old 02-10-2008, 08:31 PM
PMR = JUNK
it does it even at operating temp. i can shut it off and restart it seconds later and it still does it. could it still be the glow plugs?
Old 02-10-2008, 08:33 PM
Hmm how long are you talking? 3-5 seconds is normal. Any other issues? How does it run otherwise? Are you keeping up with the general maint such as fuel filters diesel rated oil air filters etc?
Old 02-10-2008, 08:58 PM
PMR = JUNK
its probably right around 3 or 4 seconds, its just that when i first got it, it would pretty much pop right off, now its takin a bit longer, im just worried about it gettin worse and leavin me stranded. it runs great otherwise. as far as maintenance goes, ive only had it a few months, im gettin close to doin the first oil change. the previous owner took really good care of it and kept up on the maintenance.
Old 02-11-2008, 12:58 PM
PMR = JUNK
nobody else has any thing to say?
Old 02-11-2008, 01:11 PM
PMR = JUNK
somebody...
