(NEED HELP) - Ford Powerstroke Diesel Forum
Old 02-10-2008, 07:29 PM
Send a message via AIM to tims02ford Send a message via Yahoo to tims02ford
Angry (NEED HELP)
Hey guys i have a 02 psd and i'm getting 9 mpg and 11 on the high way. The truck is hard to start when i let the glow plugs get up to temp but when i just try to start it. the truck starts like it did when i first got it.I have put a new fuel filter in and am getting the k&n intake off and putting on a afe.I do get a lot of smoke when first fire up. I all so have a dp tuner and turner it off bc i didn't want it to f up. PLEASE HELP
Old 02-10-2008, 07:31 PM
what are you mainly wanting to know?
Old 02-10-2008, 07:32 PM
what is going on with my truck NO CODES NOTHING
Old 02-10-2008, 07:34 PM
so it starts better with out the glow plugs? and gets crap for milage? there was another post with a guy that had bad milage too, I will try to find it.
Old 02-10-2008, 07:37 PM
Desert Shield/Storm Vet
Has this been a gradual decrease in milage or somthing that just happend? How many miles are on your truck?
Old 02-10-2008, 07:41 PM
duct tape & zip ties
Sounds like an Injector problem to me. I would check the UVC ( Under Valve Cover Wiring Harness). You may just have a couple bad connections at the injectors or at the pass through connection on the outside of the valve cover. Do you have any hesitation or does it sound like you have a miss at all.
Old 02-10-2008, 08:07 PM
sooo.....am i right here.....
poor fuel economy.....
truck wont start if you let the glow plugs cycle...
truck starts easily if you dont let the glow plugs cycle..
truck always smokes when you start it?? or does it smoke only cold...only warm...or only if you let the glow plugs heat up or not heat up
do you get a check engine light??
have you scanned it for codes??
Old 02-11-2008, 03:48 AM
well ya my fuel economy has been decrease and it smokes after long starts and a lot of smoke when cold. I can small the fuel strong out side of the truck. No light no codes. the truck seems to fire up faster with out letting the glow plugs worm up. At ideal you can feel like a littel mis i think this is my first psd
Old 02-11-2008, 08:48 AM
I think its a fuel problem and cant do a leak down test b/c i don't have the tools to do it so if some one lives by me that can help let me know please or help me
Old 02-11-2008, 06:01 PM
my truck has 82k and it has be a gradual decrease
