poor mileage, can't hear turbo....... - Ford Powerstroke Diesel Forum
Old 02-10-2008, 04:08 AM
I have a 95 f350, 7.3, auto, crewcab, with extended chassis and a Hodges 19foot car hauler bed installed, with 103,000 miles.
I have a very slight trmble in engine at idle, with a vehicle on the truck and pulling a 18' loaded trailer I get 6.5 MPG. I was getting 10.7 MPG with the same load. I also noticed a slight loss in power and I don't hear the turbo spooling up. No smoke. Any help is better than no help.
I'm heading to church and I'll check back this evening to see what answers I have.
Old 02-10-2008, 06:41 AM
AJF AJF is offline
Im not sure about the turbo problem, maybe check your filters. In any case some one will be around to help soon so here is a
Old 02-10-2008, 09:50 AM
I am going thru the same problems, Im down to checking the cat conv, Ill let you know if it makes a differance.
Old 02-10-2008, 10:06 AM
BIG TRUCK, SMALL DRIVER
Start with the basics, filters, oil, fuel pressure. You may want to change the CPS if you haven't.
Old 02-10-2008, 10:20 AM
thats the place to start....
first off....are there any modifications on this truck? and do you have gauges?
Old 02-10-2008, 10:28 AM
Have you pulled your air intake and checked to see if your turbo is binding or locked up? Might also check your up pipes for leaks....
Old 02-10-2008, 10:42 AM
All stock, including stock gauges.
Old 02-10-2008, 12:45 PM
check fuel pressure
check your valve cover harnesses
