Cylinder 8 contribution fail? - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-14-2013, 10:44 AM Thread Starter
what does it mean when you have code p0284 cylinder 8 contibution?
2000 f250 single cab long bed, 7.3, rebuilt stock turbo, XDP fuel regulator, injector harness mod, 17 inch pro comp extreme wheels, 33 inch dynapro tires, 5 inch mbrp exhaust, autometer boost gauge
dieselyoungster114 is offline
post #2 of 6 Old 04-15-2013, 12:08 AM
It is very common. The firing order is 1-2-7-3-4-5-6 -8. Since 8 fires right after 6 #8 may not get enough fuel. That is why Ford started using the long lead injector in #8. Some even fail on #3 and #8. I wouldn't worry about it unless you are having symptoms of a bad injector.
2001 F250 SC/LB
Afe stage1, 4" MBRP 409 SS turbo back,DP F5 Tuner,
Isspro EV guages, Wicked Wheel
Glassdude is offline
post #3 of 6 Old 04-15-2013, 06:41 PM Thread Starter
well I am having a very low boost issue and its starting to look like injectors are bad. If one injector is bad would it contribute to only building 10 psi of boost?
post #4 of 6 Old 04-15-2013, 06:43 PM
Quoted: 348 Post(s)
Feedback Score: 5 reviews
No. Something is wrong with your turbo system. Boost leaks, exh leaks, turbo itself...
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is online now
post #5 of 6 Old 09-12-2013, 07:58 PM
lookin4myPSD's Avatar
Not to hijack, but this seems somewhat related. Would a P0284 code have any correlation to white smoke coming from the exhaust when accelerating? (not when starting or when cold, just accelerating)
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #6 of 6 Old 09-13-2013, 09:17 AM
Powerstroke Junkie
NCHornet's Avatar
check the firewall for carbon build up where the up pipes are connected, there is a doughnut type seal that is known to fail and this will lower boost numbers. Check for play in the turbo wheel. Also make sure the boots in the IC plumbing are in good shape and the clamps are good n tight.
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
