High idle, stays a about 1k rpms - Ford Powerstroke Diesel Forum
post #1 of 18 Old 04-12-2013, 02:38 PM Thread Starter
Had truck worked on and they reflashed it now the truck wont idle down. It is staying up around 1k rpms. When it put it in park it seems to idle down one time but not the next to about 6-700. Any idea's?
2000 F350 2x4 superduty Dualy
5" drop
24" alcoaa rims w/ grappler uhp's
4" turbo back ex.
edge programmer
K&N intake with Napa 6637 filter
06' Grill, Mirriors, Led lights
444kyle is offline
post #2 of 18 Old 04-12-2013, 04:25 PM
Jakeman711's Avatar
The EOT sensor is one of the sensors that the PCM uses to tell if the truck needs to be at high idle. I have seen a bad EOT sensor cause this. This is only when the truck is in park though, auto trans of course.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #3 of 18 Old 04-13-2013, 05:30 AM Thread Starter
I will check. but mine does do it more often when in drive not park.
5" drop
4" turbo back ex.
edge programmer
444kyle is offline
post #4 of 18 Old 04-13-2013, 05:37 AM Thread Starter
also truck has been lobing at idle. noticed my friends did it but only when it was help wide open which caused the injectors to starve for fuel when he lets off. then after a few seconds it goes back to normal. mine will sit there and lobe the same way for ten min.
5" drop
4" turbo back ex.
edge programmer
444kyle is offline
post #5 of 18 Old 04-13-2013, 02:20 PM
Jakeman711's Avatar
Does the truck have a miss at all?
[SIGPIC]
Engine:
Body:
Future Mods:
post #6 of 18 Old 04-13-2013, 05:52 PM Thread Starter
Yes it is missing and stumbling at idle
5" drop
4" turbo back ex.
edge programmer
444kyle is offline
post #7 of 18 Old 04-15-2013, 12:14 AM
Check you ICP sensor for oil in the connector. Try unplugging it and see if the problem goes away. If it does the ICP is bad. If there is oil in the connector replace the sensor.
2001 F250 SC/LB
Afe stage1, 4" MBRP 409 SS turbo back,DP F5 Tuner,
Isspro EV guages, Wicked Wheel
Glassdude is offline
post #8 of 18 Old 04-18-2013, 06:00 AM Thread Starter
new icp and checked wires. its weird because its hanging at about 950-1100 when you come to a stop in gear. then when you shift to park it drops to about 800. which is still alittle high I think.
5" drop
4" turbo back ex.
edge programmer
444kyle is offline
post #9 of 18 Old 08-28-2013, 04:38 PM
73Z28CAM's Avatar
did you ever get this resolved??
73Z28CAM is offline
post #10 of 18 Old 08-29-2013, 07:43 AM Thread Starter
no I sold it got tired of dealing with it. went back to a truck I trust. Bought a new tundra.
5" drop
4" turbo back ex.
edge programmer
444kyle is offline
