Po344 - Ford Powerstroke Diesel Forum
post #1 of 8 Old 04-11-2013, 03:09 PM Thread Starter
Po344
I'm new here and I bought my first power stroke 7.3 built in jan of 99 I have a code on it that continues to pop up it is po344 it is causing stalling and random jerking while driving just replaced cps yesterday I haven't been able to find a short and ideas or a testing procedure could anything else cause this? I've already put new injectors in being it had two bad ones I replaced all of them replaced both uvc harnesses , the gaskets seemed fine and cps I've been digging through the harness for a day don't seem to find anything bad please help
Rustyford is offline
post #2 of 8 Old 04-11-2013, 04:20 PM
timmyboy76's Avatar
is it or has it, been raining? May want to check the wires at the CPS. Do you have a chip/tuner as well? If so, unplug it, and see what happens.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 8 Old 04-11-2013, 04:23 PM Thread Starter
Yes it has been raining I dryer the harness with brak Kleen and compressed air and no I have no chip or tuner
post #4 of 8 Old 04-11-2013, 04:28 PM
timmyboy76's Avatar
post #5 of 8 Old 04-11-2013, 04:29 PM Thread Starter
All my attempts to recreate the stall have come up with nothing including wiggling the harness its random and often always while driving or stopping it seems strang because it runs great with no loss of power and all of a sudden the tack drops for a split second while driving which ends with a jerk or while stopping it just quits and starts right back up
post #6 of 8 Old 04-11-2013, 04:31 PM Thread Starter
Thanks for the link I will check it out
post #7 of 8 Old 04-12-2013, 05:43 PM
Jakeman711's Avatar
Where did you get the CPS from? The only places one should get them is from Ford or International. Also, these sensors are notorious for going bad so you should always have a spare the the glove box along with a 13mm socket and ratchet. Again if you get the sensor from AutoZone or any other store who sells aftermarket then you are asking for trouble. Someone just posted on here about buying one from an aftermarket store and having problems.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #8 of 8 Old 04-13-2013, 10:57 AM Thread Starter
So I read your posted link guess what found that my wipers do in fact stall my truck and I did replace my cps with a grey after market I just got a new one from ford today I will install it on Sunday and see if this helps thanks again
