01 puking lots of oil from somewhere - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-09-2013, 04:50 PM Thread Starter
got an 01 that i used to drive almost everyday, was gonna go on a trip to west va and was doing an oil change the night before i was to leave. so i change the oil, start her up drive down the road, turn around go about 8 miles pull back up to the house where it was sitting before and as im pulling up i see oil leading down the street. i look under the truck and its just pissing oil.. i see it streaming out from between the engine and tranny so right away i thought rear main seal.... or is there something above that, that would leak that badly and just be running past the seal and down?
just to tie up loose ends i swapped wheels and tires and took the 6.0 to west va, 29mpg and ran like a champ...
terry6.0 is offline
post #2 of 12 Old 04-09-2013, 06:10 PM
Ford_man's Avatar
Your HPOP will leak like that and the oil will run down the vally and there is a little drain hole at the end of the vally it will run down the engine between the bell housing and out the inspection cover making it look like the rear main the rearly go out on the 7.3s.
Ford_man is offline
post #3 of 12 Old 04-10-2013, 06:10 AM
Quoted: 176 Post(s)
Feedback Score: 3 reviews
Here's an interesting video, BUT I have to warn you about this guy,,,, he makes Great Videos, that Does NOT make him infallible though. He's got some really GOOFY theories (not about this though) So, don't take him as your Guru, as many do Confirm his advice on anything else he says
POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners
NoRalPh is offline
post #4 of 12 Old 04-10-2013, 08:41 AM
timmyboy76's Avatar
sounds like you blew a hpop line.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #5 of 12 Old 04-10-2013, 09:22 AM Thread Starter
my knowledge of the 7.3 is limited... hpop easily accessable? where is it located?
terry6.0 is offline
post #6 of 12 Old 04-10-2013, 11:40 AM
timmyboy76's Avatar
top of motor, in front of fuel bowl. There's 2-high pressure lines, leaving it on the driver side. One going to each "bank" / head. They see excess of 3000+ psi, so ya, after a while of use..(150k miles to be the norm), is a good time to replace them...
post #7 of 12 Old 04-11-2013, 04:21 AM Thread Starter
what a coincedence.... it has exactly 150,000 miles on it.
terry6.0 is offline
post #8 of 12 Old 04-11-2013, 02:50 PM
Jakeman711's Avatar
Look in the valley if you see oil then you either have a HPOP line that failed, or your HPOP is leaking. If your valley is dry then it is most likly your turbo pedistal. The EBPV in the pedistal is known to leak on these engines, and trust me (I know from experience) they can leak large amounts of oil. Also, the large oil rail plugs on each end of the heads can also leak large amounts of oil if the orings fail. Rear seal failures are uncommon, but anything is possible.
[SIGPIC]
99.5 F-250 4x4, 7.3 PS
Engine:
State 1 injectors from Rosewood, GT38 (van) turbo, S&B intake, Comp Cam's 910 valve springs, Smith Brothers pushrods, AIH delete TS 6-position chip. Pyro.
Body:
2005 front end conversion, 2008 tailgate, taillights, and rear bumper.
Future Mods:
Edge CTS monitor, and 4" Exhaust (Manufacturer to be determined).
Jakeman711 is offline
post #9 of 12 Old 04-11-2013, 03:14 PM
timmyboy76's Avatar
Riffraff Diesel: Oil Rail End Plug Gasket/O-ring
post #10 of 12 Old 04-11-2013, 03:53 PM
Quoted: 176 Post(s)
Instead of guessing, buying parts you don't need, or just replacing Everything, why don't you just watch the video so you understand what the possibilities are? Then, wash out the valley and roll-up 1/2dz paper towels and slide them in there (like a giant Kotex ) and drive it around the block.
If the Front of the towels are wet the problem is around the HPOP, if it's wet in the Back it has to do with the Turbo...
It's not Rocket Science!
NoRalPh is offline
