Just bought F350- grinding noises? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 04-08-2013, 07:23 PM Thread Starter
Quoted: 2 Post(s)
I bought a 2001 F350 with the powerstroke and 6 speed last week. It has 211000 miles, and I had it checked out by a mechanic, and every thing seemed to be about perfect. Since I picked it up, I've probably driven 400 miles with no issues. It starts fine, has power, ect, but just starting today, It makes a grinding noise at various RPM range. In neutral, it starts grinding right at 2000 rpm, but when you are driving down the road, it will start grinding at 1000-1500 rpms. My first guess is that it's the turbo, but I'm not sure. How would I go about diagnosing these issues?
Also, this morning, before the truck started making the new noise, I was idling the truck while jump starting a backhoe, and even with the truck at operating temp, the rpm's were swinging between 500 and 1100 rpms. Is this normal?
TempestV is offline
post #2 of 14 Old 04-09-2013, 05:32 AM
350 ONE TON's Avatar
Sounds like ICP if the idle is jumping around. That's a pretty big swing in revs though. Pull the plug on the ICP and see if there is oil on it. If so its junk. That wouldn't explain the grinding noise though. Where does it sound like its coming from? Motor or trans?
2003 F250 XLT 6Spd 4X4 ECLB 4" lift 4" turbo back duals, AFE Stage 2 XP, superchips flashpaq (gone soon I hope) GTP38R, Gutted EBPV
350 ONE TON is offline
post #3 of 14 Old 04-09-2013, 05:44 AM Thread Starter
Quoted: 2 Post(s)
Engine compartment- it's hard to be more specific than that, but I think either passenger side, or near the turbo. It's not the tranny, it will make the noise while stopped with the clutch in.
TempestV is offline
post #4 of 14 Old 04-09-2013, 05:56 AM
Yeah that's a hard one to call without hearing it. If you think it's a turbo pull the intake tube off and check it. Any up and down or in and out play is bad. Or if the blades are chewed up
post #5 of 14 Old 04-09-2013, 05:56 AM Thread Starter
Quoted: 2 Post(s)
Also, I noticed when the engine was idling, and would jump up to higher rpms, if I tapped the fuel peddle and let off, the rpms would drop off for a bit, back down to 500.
TempestV is offline
post #6 of 14 Old 04-09-2013, 06:41 AM
Do you have the e brake set? If so its just going to high idle which is perfectly normal
post #7 of 14 Old 04-09-2013, 06:42 AM
When you said the Rpms were jumping upto 1100 I thought you meant a fast jump and then back down again. Sorry forgot to ask!
post #8 of 14 Old 04-09-2013, 07:09 AM Thread Starter
Quoted: 2 Post(s)
E brake set. As I understand it, the high idle is to help it warm up when it's cold, in this case the engine was warm. Unless it had something to do with jump starting the backhoe?
TempestV is offline
post #9 of 14 Old 04-09-2013, 05:18 PM
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
The motor will automatically go into "high idle" when the ebrake is set and the truck is in park. Did you check the turbo for shaft play?
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #10 of 14 Old 04-10-2013, 06:38 AM Thread Starter
Quoted: 2 Post(s)
I got a chance to check the compressor wheel for play last night, and there is the slightest of play side to side, none front to back. Here is the wheel:
I'll see if I can get video of the sound tonight, but in the meantime, this is pretty much what my truck is doing-
TempestV is offline
