E-350 water valve - Ford Powerstroke Diesel Forum
Old 02-04-2008, 01:03 PM
E-350 water valve
Where is the water valve on a E -350. I have went through the hood, from the inside, and all I can find is the air filter in the front and the turbo in the back. I have tried tracing the water valve actuation cable and can not trace it under the turbo to find where it ends. Must be some trick??????
Thanks,
Mark
Old 02-06-2008, 09:34 AM
mine is on the bottom of the fuel filter housing. the cable goes towards the back but loops around towards the front to hook to it. i left the air intake resonator on my bench and plugged the tube where it went. make it a lot esier to change fuel filters
Old 02-08-2008, 05:13 PM
Are you talking about the dump for the fuel filter housing? If so, on mine the black t-handled pull is right there next to the crankcase and transmission dipsticks.
Old 02-14-2008, 08:01 AM
Is the fuel filter in the front, in the middle, under the air intake tube?????
If so how do you get to it?? I have taken off the air filter housing, but can barely see what I assume is the fuel filter. It is a round top with a star pattern molded into it. if this is it I don't see any way to get a filter in and out and cannot find the water valve on it.
Old 02-15-2008, 07:06 PM
that round part with the star is the top of the housing. you put a ratchet in the star to unscrew it and the filter will be under that cap. the water valve is on the bottom of that housing in the back. there is a black cable that comes off of it and wraps around near the transmission dipstick (on a auto trans setup). on my van there was a resonator assembly that made it a major pain to change the filter. i took it out and plugged the hole with a pvc cap where it went into the air tube. its a little louder but much easier to change the filter now.
