Starts Runs Rough and Dies - Ford Powerstroke Diesel Forum
Old 02-03-2008, 01:53 PM
My 1997 will start and run like normal for about 10 seconds, then it runs rough for about 5 seconds, and then it dies. I think it could be clogged injectors but I am not sure. We changed the fuel filter, blew out the fuel lines, and cleaned both fuel tanks. We have ran out of other ideas so any advice would be appreciated. Thanks, Ryan.
Old 02-03-2008, 02:50 PM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
CPS??
Old 02-11-2008, 09:13 AM
I replaced the cps and sill nothing now i changed the fuel pump took it to the dealer and they said that in wasnt injectors or cloged fuel lines they said they cant figure it out i dnt understand i cant figure it out nothing i do to "try" and fix it isnt making a diffrence it runs like a top and then dies and the check eng light comes on i dnt knw what to do someone help please
Old 02-11-2008, 09:15 AM
Is it cold enough for your fuel to gel?
Old 02-11-2008, 09:24 AM
Yes out side but its in my heated shop its about 60 in there
Old 02-11-2008, 09:27 AM
could it be the idm
Old 02-11-2008, 09:34 AM
Can you get codes on it, that would help.
Old 02-11-2008, 09:45 AM
when i took it to the dealer they said the only code that came up was one for the trans nothing else im so frustrated
Old 02-11-2008, 09:51 AM
that was the only code it gave even while it was running, whats your fuel pressure?
Old 02-11-2008, 10:01 AM
they dnt tell me that they said that the code for the trans was the torque converter locking up but that cant b it becouse i just put a brand new trans in
