2000 F250 7.3L No start/start/dies - Ford Powerstroke Diesel Forum
Old 02-03-2008, 12:39 PM
OK Here is a commonly asked problem/question.
Problem: Driving on Super Bowl Sunday morning 1 mile down the road to get newspaper and truck died just like shuttin off ignition switch ( I didn't). Crank, Crank, Crank....no start. Wait 2 minutes crank and it starts for 3-5 seconds. Crank and no start.Left in middle of rural dirt road to get tow vehicle.30 minutes later came back. Crank, started, drove 1/2 mile down road, died again, no restart. Towed home.
Hooked up scan tool...no codes. No check engine light.
Tried starting again 2 hours later. It started up and ran for 3-5 minutes at idle and 1500-2000 rpm then died. No restart.
Scanned again for codes. No codes.
Checked fuel filter bowl...full of fuel.Drained it twice. Heard fuel pump running the stop after 10-15 seconds to fill bowl again.
Still no start.
ANY BODY HAVE ANY IDEAS??? I DONT CARE ABOUT SUPERBOWL NOW!
Old 02-03-2008, 12:47 PM
does your tach move when cranking?? if not, your CPS may be dead or you have a dead fuse (fuse #22 is the most common)
if the wait to start light doesn't come on and your tach doesn't move, mostly likely the fuse i just mention.
have you installed any chips?? if so, check the connection of whatever chips you have.
Old 02-03-2008, 12:49 PM
Other vehicle is an F250
CPS failure
From what I have read on this site, it sounds like a CPS failure. Ford has a recall and will replace for free.
Old 02-03-2008, 02:30 PM
Here is more info. NO tach movement upon cranking. Also if it sits for 2 hours it will start and run for 5 minutes/warm up, then dies.
I think that fuse is OK...the "wait to start light ' comes on. I'm leaning towards cam sensor...even with no trouble codes.
Old 02-03-2008, 03:14 PM
try installing a new cps and that should solve the issue
Old 02-03-2008, 03:28 PM
allergic to hot weather
Send a message via AIM to 95and05 Send a message via MSN to 95and05
CPS cheap and easy and almost garuntee!
Old 02-04-2008, 05:11 PM
crank timing senser.
james
Old 02-04-2008, 05:13 PM
cam sensor??
Old 02-04-2008, 05:19 PM
CPS dealershipe should change for free and tow it there also under the recall they did mine
Old 02-04-2008, 06:35 PM
Get it fixed today? Let us know when you do. Good luck.
