Blown turbo? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 04-04-2013, 07:28 PM Thread Starter
Blown turbo?
I'm wondering if a blown turbo would make it run rough? I have an 02 and I think just blew the turbo but not 100 percent. Runs rough, smokes white and has an oil leak somewhere up around the turbo. Any suggestions?
Fastass111 is offline
post #2 of 7 Old 04-04-2013, 07:49 PM
Macon's Avatar
Find where the oil leak is. Could be a pedestal problem.
Take of the intake and check the turbo. If it spins freely and the blades aren't ate up, then the turbo should be fine.
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 7 Old 04-05-2013, 11:12 AM Thread Starter
Spun the turbo and it seems fine, find look fine too. Oils coming from somewhere on the back or bottom side of turbo it seems. There's oil inside both the lines to and from the inner cooler. Is that normal? And what do you mean by a pedestal problem? I'm sorry I'm relatively new to the powerstroke and don't know a ton about it
post #4 of 7 Old 04-05-2013, 11:30 AM
Macon's Avatar
The pedestal has four o-rings that can leak. The EBPV can also be the cause of the leak. You'd have to get up in there some more to figure out exactly which. Clean it, then start it and find the leak.
New o-rings are about $6, EBPV rebuild kit is ~$100, or, an EBPV delete pedestal is ~$120 + a remount kit for ~$20. All at DieselOrings.
This is likely a different issue than the rough running. What kind of aftermarket gauges do you have?
2002 F250 CCSB 4x4
Macon is offline
post #5 of 7 Old 04-05-2013, 04:18 PM Thread Starter
The running rough started at the same time as the leak and white smoke is the only reason I think it's not two different things but I guess it could be. I put an edge tuner on it that I was testing out and it was i for three days when this happened so that kind of scares me. I just have egt and boot pressure
post #6 of 7 Old 04-05-2013, 04:36 PM
Macon's Avatar
Is the Edge still on it? If so, take it off. White smoke could be several things, and let's just hope that the Edge was giving you bad timing for whatever reason.
2002 F250 CCSB 4x4
Macon is offline
post #7 of 7 Old 04-05-2013, 08:20 PM Thread Starter
Ok I will give it a shot and see what happens. Thanks
