HELP!!!! I WILL PAYPAL $50 TO THE PERSON THAT SOLVES/DIAGNOSES MY PROBLEM - Ford Powerstroke Diesel Forum
post #1 of 22 Old 04-01-2013, 03:30 PM Thread Starter
Arrow HELP!!!! I WILL PAYPAL $50 TO THE PERSON THAT SOLVES/DIAGNOSES MY PROBLEM
I have a 2001 Ford Excursion 4WD Limited
The truck 44,000 Original Miles on it
In an effort to improve Fuel mileage as well as to have functioning gauges, I installed an Edge Juice With additude INSIGHT CS
Before installing the edge the truck was 100% bone stock all the way down to the factory tires (well so i thought)
THE TRUCK RAN AND DROVE PERFECTLY FINE WITH NO ISSUES AT ALL
(it actually did have an ABS light that would come on and then go off randomly but was off most of the time)
I purchased the Edge unit on ebay and installed it shortly after reciving
When i initially completed the install the attitude monitor read that it was unable to detect the factory setting and that i needed to go load the factory/stock tune on to the Juice via edges online website
I removed the Juice and did and completed the flash from Edges online website
I reinstalled the juice and followed all the prompts until the install was complete
I promptly started the truck, letting it idle for a while. I noticed that it was idling rough. I then went and looked at the gauge cluster and noticed the SES light was on
I used the Attitude to clear the codes and attempted to drive the truck.
Right when i pulled out of the drive way and shifted from first to second gear i noticed it was a hard firm shift that was delayed longer than normal
(so instead of shifting at 1800RPM it shifted at 2500RPM)
Directly after observing the abnormal shift the SES light came back on
I cleared the Code again and continued to drive it.
While driving it i noticed it was in and out of power and hesitating. I finally arrived at a place i could run it up and hold out each gear.
Up on taking off from a dead stop it falls on it face and when shifting from gear to gear it is a very hard and firm shift (higher than normal in the rpm), most of all i noticed that it was bucking (pretty much missing ) the whole way up to 80mph
I returned home and viewed the codes on the Edge Attitude
The codes it threw were:
P0500
P0380
P1316
I cleared the codes and uninstalled the programmer completely and founf that it was still kicking the SES light on and still performing the same way it did as when the programmer was installed on it
I took the juice in and reflashed the the stock settings back in to the programmer (from edges site)
I then reinstalled the programmer again yielding the exact same result
I called edge and talked to there service techs
They explained that there factory flashes they offer on the website are 100% up to date
I then went back over and checked every connection plug and harness wire in and around the engine compartment (everything was fine)
I finally was left with not other choice but to take the truck to the dealership.
The dealership ran there scan tool on it and found that there was no issues. They also verified that the flash i had downloaded from edges website was the most current and up to date
The last test the STEALERSHIP did was a "BUZZ TEST", in which it passed.
I spoke with the tech directly and he said he would maybe try replacing the cam shaft postioning sensor as sometimes they malfunction but work enough to pass diagnostic tests.
I replaced the sensor he suggested and still no improvment
I have swapped out the IDM from a similar truck and found no improvement
I do have another 7.3 Diesel truck that i was going to swap over the entire Computer but feared it may cripple my other vehicle as well so i did not do that yet (but will if i knew it wouldent hurt my other truck or throw it in to theft mode)
If the truck is driven more than 10 or 15 miles it will eventually throw all 3 of the codes listed above
THE SAME 3 EVERY TIME
So at this point I am all out of options
I have spent countless hours and a lot of money trying to repair my truck and have had no success
If anyone can help me diagnose the problem, point me in the right direction the fixes the problem, or can possibly even throw out a couple long shot guesses, I will pay-pal or even mail you $50 bucks or even more if so warranted
If there is something i could possibly be missing when installing or uninstalling programmer. PLEASE MENTION IT
If you have had a similar problem or have have thrown one of the same codes listed, PLEASE TELL ME ABOUT IT
IF YOU HAVE ANY SUGGESTIONS WHAT SO EVER PLEASE SPEAK UP. At this point i'll try anything
If you have any questions or need more description, please ask
I am an honest person, if your suggestion or help leads to the correct operation of my truck
I WILL PAY YOU ACCORDINGLY FOR YOUR TIME AND EFFORT
I can be reached anytime day or night at
580-716-0563 CALL or TEXT
Thanks again for all your help everyone
Details:
2001 Ford Excursion 4WD 7.3 Diesel
44K Miles
Codes:
P0500
P0380
P1316
Contact via TEXT or PHONE at
580-716-0563
twice_blown is offline
post #2 of 22 Old 04-01-2013, 03:51 PM
BK1977's Avatar
Was it a used programmer?
Sent from AutoGuide.com App
03 f-250 CCLB FX4 6.0. H-11 studs, egr delete, swamps 58 v ficm, sct sf3, autometer ultralight boost, pyro and trans temp. Complete 08 bed. And a few other things
BK1977 is offline
post #3 of 22 Old 04-01-2013, 03:57 PM
dalton1's Avatar
you may need a new valve cover harness, or a new clip to hold the connection tight, I would double check those.
03 F-250 Lariat Crew Cab SB 6.0L Auto 4x4
5" exhaust, AFE intake, Blue spring mod, EGR Delete, 58v FICM, Warren 175/75 injectors, Powermax Turbo,
ARP Head Studs, Coolant filter, Innovative tunes
Pine Tree Powerstroke Association Director
pm me for chapter info
dalton1 is offline
post #4 of 22 Old 04-01-2013, 03:57 PM
Quoted: 177 Post(s)
Feedback Score: 3 reviews
The Only code you have, that would effect the way the engine runs, is the 1316. AND the 1316 isn't really a "code" at all...
What it's telling you is that the IDM sees a fault, and a buzz test needs to be performed to resolve further codes. I can only assume the dealership would have found those codes but, if it's a reoccurring fault there MUST be something to it!
Can the Edge do a Buzz Test for you? That's where I'd start, another buzz and rescan for the produced codes. Our trucks are Very prone, especially after the years have passed, to having trouble with the UVCH connections (UnderValveCoverHArness to the injectors and GlowPlugs - the OTHER code you have). Since they are an electrical connection that's, kinda, unplugging itself, it can be intermittent. Meaning, unless your Tech knew about these engines, it might have had a good enough connection at the time he tested to Pass the Buzz but is still going to give you trouble.
If you're going to keep the truck for awhile, and with the mileage you Should, invest in an AutoEnginuity scanner so you can do a proper diagnosis for yourself (might as well return the Edge if you did, the AE and a Chip from a reputable programmer is a Far better way to go)
NoRalPh is offline
post #5 of 22 Old 04-01-2013, 03:59 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Don't care about the money but I'd pull the valve covers and inspect the UVCH.
dhanna6powerstroke is offline
post #6 of 22 Old 04-01-2013, 04:03 PM Thread Starter
Yes, it was used Briefly
post #7 of 22 Old 04-01-2013, 04:06 PM Thread Starter
I have heard a lot about that issue and really thought about going ahead and looking in to it but figured if it passed the "buzz test" everything along those lines was operating correctly
thanks man for your reply
I think im gonna have to go ahead and pull the VC as you suggested
thanks again
post #8 of 22 Old 04-01-2013, 04:08 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 276 Post(s)
You had said the dealership said it passed the buzz test. Does this dealership have diesel techs that did the work? Maybe this is somethin you want to look at and check as a possibility. It would explain the injector and glow plug codes but not the speedo code....
7.3 Diesel Powerstroke misfire runs rough code P1316 injector wire harness connection - YouTube
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #9 of 22 Old 04-01-2013, 04:12 PM
Quoted: 276 Post(s)
Nevermind... While i was typing messin around, people already posted it...
post #10 of 22 Old 04-01-2013, 04:17 PM Thread Starter
Thanks so much for the reply
Since the dealership performed the buzz test and it passed, i kinda stopped looking in to the harness issue
The tech was a diesel tech and was aware of the harness probs but he said being it had suck low miles and passed the buzz test, i should prob look else where for the problem
SO it is possible to pass the buzz test and still have the harness issues??
The edge cannot perform a buzz test but has a built in code reader, thats about it
Is edge an unreliable programmer?
it was appealing because of the gauges it offered and the "on the fly" settings
THANKS AGAIN BUD FOR YOUR REPLY
I am going to look in to pulling the valve covers off soon
DO I NEED TO BUY NEW VALVE COVER GASKETS OR COULD THEY BE REUSED?
THANKS AGAIN
Tags
codes , edge , programmer , tune
