Flutter and white/blue smoke that smells like diesel - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-31-2013, 02:04 PM Thread Starter
Colin7.3's Avatar
My truck has a slight flutter when you first hit the pedal and then there is a little blue/white smoke that puffs out abs then clears up. New injector o rings pass contribution and buzz test.
Now the funny thing
When I fill the fuel bowl up with Lucas fuel cleaner. The truck doesn't flutter or smoke and will blow a wisp of black smoke on hard throttle instead of white
Any ideas?
Colin S. Age:22 Certified Diesel Tech, Infantry US ARMY
E99 7.3 6spd 4x4 6637, 4" straight pipe, 365,000 miles
"wear your high mileage as a badge of honor"
04 GMC 2500 4x4 Duramax/Allison
Colin7.3 is offline
post #2 of 14 Old 03-31-2013, 05:33 PM Thread Starter
Colin7.3's Avatar
Will also add it does not lose coolant at all.
Colin7.3 is offline
post #3 of 14 Old 04-02-2013, 06:46 PM Thread Starter
Colin7.3's Avatar
Bump anyone?
Could it be air in the system still since I just swapped injectors?
Colin7.3 is offline
post #4 of 14 Old 04-05-2013, 08:36 AM Thread Starter
Colin7.3's Avatar
Anybody? Bump?
Colin7.3 is offline
post #5 of 14 Old 04-05-2013, 09:42 AM
timmyboy76's Avatar
i'll throw a bone. Check the icp plug for oil. If so, it needs replacing. Also, white/blue, to me, is raw fuel. Maybe the ipr is on its last leg. Only sure way to know, is get it on a scanner and watch the duty cylce, icp pressure...Sounds like the injectors are not firing. Also, do a buzz test.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #6 of 14 Old 04-05-2013, 09:42 AM
timmyboy76's Avatar
also, check the ipr nut, see if its loose or the tin nut is off.
post #7 of 14 Old 04-05-2013, 11:50 AM Thread Starter
Colin7.3's Avatar
Thank you ill check hose out. What should the duty cycles be when idling?
Colin7.3 is offline
post #8 of 14 Old 04-05-2013, 11:57 AM Thread Starter
Colin7.3's Avatar
I unplug the icp sensor and the smoke clears up a little bit but it still slightly there.
The plug does have oil on it. So I should replace the plug and icp or just the plug?
Colin7.3 is offline
post #9 of 14 Old 04-05-2013, 11:58 AM Thread Starter
Colin7.3's Avatar
Ipr nut is tight
Colin7.3 is offline
post #10 of 14 Old 04-06-2013, 06:44 AM
Replace the ICP, clean the plug.
Russ
Late '99 F-350 7.3l 6sp 2wd aftermarket dually kit 255,000mi
STOCK
Deeslfxr is offline
