Oil Leak - Ford Powerstroke Diesel Forum
Old 01-28-2008, 02:31 PM
Send a message via Yahoo to Anson
Oil Leak
2002 F250 7.3 PSD has anyone had a problem with there turbo leaking, the valley is filled up and have lost quiet a bit of oil on the ground just curious if anyone know what this may be. Thanks
Old 01-28-2008, 02:36 PM
what motor??
Im gonna assume its a 7.3. More than likely it will be one of the three fittings on the high pressure oil pump. There are two on the passanger side of the pump below the fuel filter on the drivers side of the fuel filter. There is also an 11/16 plug on the back of the pump that is sealed by the same type of o ring that also leaks sometimes....
