HPOP fitting ????? - Ford Powerstroke Diesel Forum
Old 01-28-2008, 08:28 AM
HPOP fitting ?????
Ok got the oring kit ready to change them caught the leak before it got real bad. One ? do the high pressure hoses swivel on the fittings or do you have to take the hoses off to remove the fittings to get to the orings. And if you do have to remove hoses how and do you need the special tool it talks about in the paper work you get with oring kit. Thanks ahead of time.
Old 01-28-2008, 09:15 AM
Any ideas looked in past threads and no one mentions this.
Old 01-28-2008, 04:34 PM
One more time and i quit how do you get high pressure line fitting lose ive read two different ways and still cant get them lose
Old 01-28-2008, 05:37 PM
International Threat
I just kept turning the fitting until it kind of popped off... and you have to be careful - there is a small plastic piece and a spring in the 2 on the side of the HPOP and the one on the back is just a plug with an O ring...
Old 01-28-2008, 05:42 PM
I also removed one of the fuel lines. Might have been the one to the FPR... but I can't be certain since I'm at work.
