2000 F250 4x4 No Start - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-26-2013, 04:08 PM Thread Starter
Truck stuttered a couple times, then stalled. Restarted twice and then quit. Stored codes for CMP sensor and EBP sensor. Replaced both only to cure the EBP code, still P0340 code and still no start. Replaced CMP sensor again with no change. Visually inspected wiring from sensor to engine connector, I do have 5.0vref at sensor. With Modis hooked up there is no RPM reading during cranking. Any ideas? BTW, truck has 266,000 miles on it and until this problem ran flawlessly. Also it is bone stock, auto trans. Thanks in advance for any help.
Russ
Late '99 F-350 7.3l 6sp 2wd aftermarket dually kit 255,000mi
STOCK
Deeslfxr is offline
post #2 of 11 Old 03-27-2013, 04:34 PM Thread Starter
Alright, figured it out today, kinda by accident. Anyone want to guess what it was? Hint: No parts needed replacing.
Russ
STOCK
Deeslfxr is offline
post #3 of 11 Old 03-27-2013, 05:30 PM
Macon's Avatar
Fuse? loose connector?
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #4 of 11 Old 03-30-2013, 01:25 PM
What was the problem. I have changed the cam sensor with 4 diffrent ones since you can buy them brand new and not working.
hypertenchan is offline
post #5 of 11 Old 03-30-2013, 04:57 PM Thread Starter
I finally suspected the PCM and upon removing it to get the part number I noticed some corrosion on the lower edge of the case (side closest to the floor when installed). Decided to take the covers off to see how far the moisture got. After removing the aluminum cover I found corrosion on the ends of the connector pins where they are soldered to the board. I can only describe it as tiny pieces of cauliflower or cotton looking balls on the ends of the pins. Typical of aluminum corrosion, the 'balls' were large enough to bridge across 2 or 3 pins each, and upon touching them, I noticed they were damp. Sprayed the area with electronic cleaner, blew it off with air, a light coating of silicone spray, and reassembled. Re-installed the PCM and tested, engine lit right up and has not missed a beat since. I figure the moisture was enough to mask the signal of the cam sensor, and generate the code. I hope this helps someone else out there.
Russ
STOCK
Deeslfxr is offline
post #6 of 11 Old 03-30-2013, 05:00 PM
Macon's Avatar
I'm glad you found it and were of the mind to look deeper and fix it yourself. You should keep and eye out for what caused the moisture to get in there, as that's not exactly normal.
2002 F250 CCSB 4x4
Macon is offline
post #7 of 11 Old 03-30-2013, 05:02 PM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
I'd suspect your windshield is leaking in the lower corners (they often do) and dripping onto the GEM & PCM. Have a look, if it needs to be fixed, do it or it's gonna happen again
NoRalPh is offline
post #8 of 11 Old 03-30-2013, 05:05 PM
Macon's Avatar
Ah, I thought the water only got to the GEM that way.
2002 F250 CCSB 4x4
Macon is offline
post #9 of 11 Old 03-30-2013, 05:24 PM
Quoted: 133 Post(s)
Oh no, the GEM is just "First-in-Line" with the PCM below it
NoRalPh is offline
post #10 of 11 Old 03-31-2013, 05:52 AM Thread Starter
I know what caused it because I saw the condition of the floormats. It's a company owned plow truck, the only care or cleaning it gets is when it comes to me with a problem. Snow and salt accumulate on the floormat and then the heater cooks it, it evaporates, and attacks.
Russ
STOCK
Deeslfxr is offline
