Quick AEginuity question - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-26-2013, 11:33 AM Thread Starter
azkcr's Avatar
Quoted: 3 Post(s)
Angry Quick AEginuity question
Hi,
we have a 1999 7.3l that is TERRIBLE to start in the mornings even when plugged in.
I know that there are a few injectors that are not functioning until it has been started and run for a bit.
When you first start it, the autoenginuity says that #3,5,8 have a high/low issue.
Once it runs and starts to smooth out, all the injectors are fine in the Contribution Test.
Is there an electrical issue or do I have 3 failing injectors???????
Thanks,
-Ben
Ben Conner
LSP Assistant Director
Got every PSD made...
My DD: '13 6.7L with Optimus Prime's wanker still on the exhaust
azkcr is offline
post #2 of 6 Old 03-26-2013, 02:13 PM Thread Starter
azkcr's Avatar
Quoted: 3 Post(s)
bump.............................................. ..........
Ben Conner
azkcr is offline
post #3 of 6 Old 03-26-2013, 03:52 PM
Quoted: 28 Post(s)
Possible idm? Sounds kinda like the problems with the 6.0 and the ficms
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #4 of 6 Old 03-27-2013, 04:44 AM Thread Starter
azkcr's Avatar
Quoted: 3 Post(s)
Well I would be worried that it was the whole side and a harness might be loose.
But since it's failing injectors on both sides of the motor and they eventually clear up makes me wonder.
I just don't know how to diagnose which ones I should replace
Ben Conner
azkcr is offline
post #5 of 6 Old 04-01-2013, 09:05 AM Thread Starter
azkcr's Avatar
Quoted: 3 Post(s)
Still no good info yet
Ben Conner
azkcr is offline
post #6 of 6 Old 04-01-2013, 10:25 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
My guess is inj just need replaced.
I can't remember since it's been awhile but you test em hot or cold and if they failed, needs replaced.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
