DTC issue.... - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-25-2013, 03:41 PM Thread Starter
etnies69924's Avatar
DTC issue....
i have an 01 7.3, thew a P1670. batterys are good (12v just static test on dash batt gauge was in red) cleared code, now batt gauge reads normal. when i turn the key to ON, all gauges come on, still with key on engine off the dash looks as if i turned the key off and turned it back on again. when i turn the key to start it, it acts as if the batterys are dead ( no crank, battery gauge reads normal). i think it could be a broken circuit between the IDM relay and the PCM relay...has anyone ever seen this? any help would be great thank you
etnies69924 is offline
