99 7.3 DEAD - Ford Powerstroke Diesel Forum
post #1 of 19 Old 03-24-2013, 10:11 AM Thread Starter
99 7.3 DEAD
Was running great with 0 problems. Drove it home, parked it, came back about 2 hrs later and it started but was missing badly. I killed and tried to restart and it hasn't started since. Changed fuel filter and it seems to have good pressure to the fuel filter but still doesn't even try to start. Started and ran fine on small dose of ether. I have a hypertech tuner and it doesn't show any codes. Any ideas?
elliott79244 is offline
post #2 of 19 Old 03-24-2013, 10:33 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Pull the chip first.
DON"T ether it
It seems to have pressure or it does? What is the PSI?
So with ether it actually caught, and ran and idled on it's own?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 19 Old 03-24-2013, 10:37 AM Thread Starter
Haven't checked the pressure but after trying to start the filter lid has alot of pressure on it. After ether it ran for a couple of seconds then died, but wasn't missing.
post #4 of 19 Old 03-24-2013, 10:39 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Ok so it only ran on whatever ether was in the system. That means you either have a lack of high pressure oil, fuel, or the injectors aren't being electronically actuated to fire.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #5 of 19 Old 03-24-2013, 11:31 AM Thread Starter
Any checks that I can do?
post #6 of 19 Old 03-24-2013, 11:40 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
whats your idiot gauge for oil pressure read? and do you have scantool or some kind of monitor?
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #7 of 19 Old 03-24-2013, 11:57 AM
jesilvas's Avatar
Quoted: 2 Post(s)
Yea, you can watch for the oil pressure "gauge" to move after a while, and I think the tachometer should move on your truck while cranking too.
Also, does your WaitToStart light come on with KeyOnEngineOff?
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 19 Old 03-24-2013, 12:07 PM Thread Starter
Oil pressure comes up to middle while cranking, wait to start operates as normal, tach comes up a little. Engine smokes when turning over. No scan tool except my hypertech until tomorrow.
post #9 of 19 Old 03-24-2013, 01:10 PM
Quoted: 4 Post(s)
Unplug the icp sensor and see if it will start. Plug the block heater in see if that helps also.
mcgoo422000 is offline
post #10 of 19 Old 03-24-2013, 01:18 PM Thread Starter
Icp sensor connector is oily but did crank an run rough while it was unplugged. Block heater is plugged in.
