Engine stays cold even at 40 degrees outside - Ford Powerstroke Diesel Forum
Old 01-21-2008, 09:34 AM
It never gets above the line that reads normal I don't have a reg temp gauge on my truck (97 3/4 hd 7.3) to tell me what temp. it's running but the gauge works .
Old 01-21-2008, 09:40 AM
Send a message via AIM to 4everlearning
When you turn the heater on does it blow hot air?
Old 01-21-2008, 09:44 AM
heat
Yes it works fine
Old 01-21-2008, 09:45 AM
fine
well after I drive 5 or 6 miles
Old 01-21-2008, 09:53 AM
Thats normal. I think I would check that guage or the sending unit.
The heater wont blow hot air unless the engine is heating up. The heater gets its heat from blowing air threw the heater core that is like a little radiator that has hot coolent runing threw it.
