Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Powerstroke Problems > 99-03 7.3 Motor Problems
Old 01-20-2008, 06:40 PM
Kent Kent is offline
a lot of air removal for the experinced Mechanic
How would you get a lot of air out if you could drive it and was'nt that good of a mechanic and lived on disability.
Old 01-20-2008, 07:02 PM
air
come on fellars I'll take a educated guess on this one all i've been doing is pusing in the fuel pressure valve and letting fuel flow out.
Old 01-20-2008, 07:15 PM
air
some one has a idea come on!
Old 01-20-2008, 07:56 PM
air
I don't want to give up on you guys yet I know someone has a Idea
Old 01-20-2008, 08:02 PM
SMKSTAX SMKSTAX is offline
KCR DIRECTOR
My guess is keep letting air out of the schrader valve. Then run the truck good and hard for 10 minutes. If you get nothing but fuel out of the valve their should be no air left.
Old 01-20-2008, 08:05 PM
I did that
I'll just continue till all the must be small pockets of air break loose.
Old 01-20-2008, 11:45 PM
adfields adfields is offline
Drive it. If it's not running right in 10 miles you have other trouble.
Old 01-20-2008, 11:51 PM
Powerstroke W/smoke Powerstroke W/smoke is offline
ya i would double check the hoses which you've prob done already from the sound of it. good luck bud here's a bump
Old 01-21-2008, 09:57 AM
AIR IN FUEL MAYBE
Let's see if anyone today has got a new idea
Old 01-21-2008, 10:27 AM
air
air in fuel must be hiding in pockets any ideas or does it just take a while to get rid of it all
