i need help with a 7.3 belt tensioner - Ford Powerstroke Diesel Forum
Old 01-19-2008, 08:24 PM
Send a message via AIM to tims02ford Send a message via Yahoo to tims02ford
belt tensioner
hey guys if a belt tensioner is going bad will it not give me the right oil psi?
Old 01-20-2008, 04:36 AM
ok come on guys i need help here.
Old 01-20-2008, 05:01 AM
<<---"Shadow"---
Bumpin for ya. Kinda wanna know the answer to this myself.
Old 01-20-2008, 05:23 AM
Send a message via MSN to pinkfloyd
Old 01-20-2008, 05:33 AM
hey guys i need help with a belt tensioner. if the belt tensioner is going bad will it not give me the right oil psi.
Old 01-20-2008, 05:43 AM
check by feeling how tight your belt is if it is tight there is nothing wrong with your tensioner also it would be squealing if it wasnt tight enough
Old 01-20-2008, 05:44 AM
Desert Shield/Storm Vet
Im pretty sure the oil pump is gear driven. I know the hpop is
Old 01-20-2008, 05:48 AM
well the belt is squealing all the time not loud tho
Old 01-20-2008, 06:16 AM
both oil pumps are driven internally with gears. Is it a squeal or a chirp that goes away when you rev above idle?
Old 01-20-2008, 06:25 AM
it is a chirp and will not go away.
