Another HPOP Question! - Ford Powerstroke Diesel Forum
Old 01-19-2008, 09:03 PM
Cynic
I purchased a used HPOP. The numbers are 449c91 and 1072713A. I was told it came off a 2000-01.
Now for the question/problem. I want to remove the back plate at find out if it is a 15 or 17 degree pump. I removed the spring clip no problem, but the plate WILL NOT COME OFF!
I need some ideas guys. Nothing destructive please.
Old 01-19-2008, 10:21 PM
Aaawww man, your taking all the fun out of it
Old 01-20-2008, 12:14 AM
Shaking the Bush Boss
Old 01-20-2008, 04:10 AM
Send a message via MSN to pinkfloyd
Old 01-20-2008, 04:38 AM
I have never taken a HPOP apart, so I wont be too much help. What I would suggest doing if you don't get any help here on the ORG is to contact a company like Terminatior Engineering or someone else that deals with high pressure oil systems all day long and maybe they'll give you some good tricks to taking the pump apart. I'm sure someone from here will be able to help you though. Good luck!
Old 01-20-2008, 05:26 AM
Cynic
I spoke with Bob at Dieselsite. He gave gave me the info of what I needed to look for. I didn't think to ask how to do it because it looked simple enough.
Old 01-20-2008, 05:29 AM
well Monday morning will be here soon enough and you'll be able to contact Dieselsite and see what they have to say.
Old 01-20-2008, 05:58 AM
cj41foleyisathief
DUC TAPE works every time. Just remove the snapring and use the tape. May take a few times but it will come off.
Old 01-20-2008, 06:00 AM
cj41foleyisathief
BTW bearing = 15* HPOP and bushing = 17* HPOP
Old 01-20-2008, 06:03 AM
Desert Shield/Storm Vet
Yep if the snap ring is off and its sticking use the tape thats a good trick. Its probobly got some oil in the back side creating a little bit if stickem for a lack of a better term
