Water pump - Ford Powerstroke Diesel Forum
Old 09-03-2006, 11:45 PM
Water pump
I have changed water pumps many times before but never on a diesel. I just cannot figure what the deal is with my 01 stroker pump it started leaking so I thought new pump time. Then, it stopped leaking for a couple of days, then started again, not a a lot, then stopped. I may as well change it or I will be asking for it later. Man, they are expensive 188.00 life-time warranty. Does anyone know if I need any special tools or not? Thanks.
Old 09-04-2006, 05:20 AM
water pump
this should help!
Old 09-04-2006, 08:41 AM
the only special tools you will need will be fan clutch wrenches to take the clutch of the water pump
Make sure to put a bottle of the ford diesel coolant additive in after you get it fixed. Without it, the water pumps in these trucks commonly only go 100k.
