Need advice on changing oil pump / injector pump
Hi, i need to know how to change the high pressure oil pump on a 99 7.3 has anyone done this?
what do you need to know? its not bad just jump in and do it.
No too hard. I wish I would of taken pics when I r&r'd mine. Let me see what I can come up with.
1. Remove the turbocharger compressor manifold.
2. Remove the fuel filter/water separator assembly. 3. Remove the high-pressure oil pump reservoir plug. 4. Using the Oil Suction Gun, remove the oil from the high-pressure oil pump reservoir. 5. Using the High-Pressure Line Disconnect Tool, remove the hoses from the high-pressure oil pump. 6. Disconnect the electrical connector from the Oil Pressure Regulator. 7. Remove the bolts and the cover from the engine front cover. Position the wiring harness aside. 8. Remove the drive gear bolt and washer from the drive gear. 9. Remove the bolts and the high-pressure oil pump from the engine front cover. Remove and discard the gasket 10. Remove the Oil Pressure Regulator from the oil pump. NOTE: If the high-pressure oil pump is to be replaced, remove the Oil Pressure Regulator from the pump. INSTALLATION Follow the removal procedure in reverse order. CAUTION: Make sure that the drive gear is fully seated on the high-pressure oil pump before installing the bolt and washer. Otherwise, the drive gear may not seat properly, causing binding or slippage resulting in a no oil flow condition. Follow the removal procedure in reverse order. |
I read in the manuals the last part. CAUTION: Make sure that the drive gear is fully seated on the high-pressure oil pump before installing the bolt and washer. Otherwise, the drive gear may not seat properly, causing binding or slippage resulting in a no oil flow condition. how do you tell if the drive gear is seated there isn't a keyway or anything on it best that i remember it just sits on the shaft
