#6 injector smokes at idle - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-13-2013, 07:32 PM Thread Starter
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
I have been having issues with my 2000 7.3L. The # 6 injector smokes blue at idle but will fire clean at 1300 rpms . I can see black smoke when driving under slight acceleration and will blow heavy black smoke when under hard acceleration. This truck will blow normal amount of black smoke but this is excessive. I made up a wiring harness for the dr side valve cover with toggle switches so I can turn off and on each injector. # 6 when switched off will not affect the idle (rough) and it won't smoke when off . All the other injectors make a dramatic change in the idle when switched off. I changed the #6 injector , new valve cover gasket , new UVCH, and put in a known good IDM ,all with no change on #6. I get 4.8V on each injector when idling , even #6 ,so the signal from the iDM is good , buzz test is good. So now what ? I can swap neighboring injectors to see if the problem follows the injector. Any other suggestions?
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #2 of 4 Old 03-24-2013, 05:38 PM Thread Starter
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
Found out what the problem is. It appears that when I changed #6 injector ,I must have pushed the push rod off to the side causing it to unseat from the cup. It rode on the edge of the rocker arm which kept the valve from seating. It caused a lot of blue smoke at idle but seemed to burn clean above 1300 rpms.
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
post #3 of 4 Old 03-24-2013, 05:50 PM
700xxmaniac's Avatar
So basically it wasn't geting full compression. I though that would blow out white smoke?
Sent from AutoGuide.com App
99 ford f-250 crew cab powerstroke
-skyjacker 6'' lift
- 395-70r-16 mickey tomson baja mtz
-sct tune
-stright pipe (vrrrooom)
-cops are in love with the thing
08 TRX700XX
-uni
-primary drive 13t
-pclll
-cp 11:1
01 recon es 250
-kenda 22'' bear claw
-53mph top speed
700xxmaniac is offline
post #4 of 4 Old 03-25-2013, 07:43 PM Thread Starter
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
No the smoke was blue, unburned fuel. The valve was held open by about 1/8 ", no compression at idle, burned cleaner above 1200 rpms. I changed out #6 , 3 times before I found the problem, I was a bit careless trying to change the injector in a hurry and it caused about 2 weeks worth of headaches.
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
Isspro 3 Gauge Pod
Banks Big Head
298K
