p1670
ok I cleared code it comes back dont now where idm is in 99 psd to check for bad wires. Replaced Cam senor. Replaced Fuel pump--brought fuel pressure back up to 60psi. Changed Oil (Rotella T 10W30) and filter. Still misses and dies. 99 - 7.3L Still getting Code P1670---Help?
Drivers side front inner fender well, the IDM is located just rear of the highest spot on the wheel well.
looked but not in the same spot as 96 psd unless it is under air cleaner and the fuse box
IDM in 99
I found the IDM in the 99. Hint to others -- take off inner fender panel on drivers side and look up! Who knew?
