2000 7.3 Rough Idle Low Power - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-13-2013, 12:50 PM Thread Starter
I will attempt to be as descriptive as I can since I have searched and come up empty handed so far. This problem was intermittent until yesterday and now it is a steady problem. The engine seems to have a miss in it, it idles rough and when i press the accelerator the miss becomes more pronounced. You can hear it through the exhaust and also at the engine and the engine rocks more than it should. The other day when i was coming home from work it started and seemed to be in and out for example i was going up a hill and it would be running rough, low on power then all the sudden it would be fine all the power would be back and i would be hauling *** but then as soon as the problem went away it was back again. There is no SES light on and i have changed my oil very recently and i changed my fuel filter this morning. Any help is appreciated.
2000 F250 CCSB 7.3 PSD 6 Speed CFM Intake Manifold AFM Stage 2 Intake Snow Performance Water/Methanol Injection 160/100 Injectors GTP38R Adrenaline HPOP 203* Thermostat Air Dog II Gear Vendors Over/Underddrive 450HP Clutch 4.88 Gears ARB Lockers Mishimoto Intercooler Turbomaster Wastegate Controller 4" Turbo Back Exhaust DP Tuner Icon 4" Lift 37" Procomp Mud Terrains Fabtech Tration Bars
wallace2000 is offline
post #2 of 4 Old 03-14-2013, 05:54 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 4 Post(s)
Check the tin nut on the back of the IPR, make sure its tight. Check the ICP for oil in the connector. Have you changed out the CPS? Possible loose connection on the UVCH check out this mod 50 cent mod - Ford Truck Enthusiasts Forums
PLEASE HELP!! E99 runs really rough!!
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #3 of 4 Old 03-14-2013, 10:45 PM
I had a similar issue. I changed IPR, ICP and CPS together. No more problems.
Greenman01 is offline
post #4 of 4 Old 04-08-2013, 12:09 PM Thread Starter
Ok ill check all that. I haven't done the 50 cent mod. I've been in the field for a few weeks so I haven't had time to work on it. Thanks for the help
