lose of power - Ford Powerstroke Diesel Forum
post #1 of 5 Old 01-16-2008, 07:06 AM Thread Starter
lose of power
After changing my water pump i had the problem occur that is described as the CPS going bad, the jerking and dieing problem. Now i have replaced the fuel filter and have a check engine light and a dramatic loss in power that kicks in around 2000rpm. The light comes on just as the lack of power sets in. then the power lag stays until i turn off the truck and crank it back up. I drove it for 20 miles like this this morning. Quite honestly, it sucked. Does anyone think the CPS could cause these problems also. I haven't had the chance to read the codes yet but wanted to get some opinions before i get off work and head home to roll up my sleeves and dig in to this problem. Any and all opinions are appreciated and welcome. thanks
Stokin' Fool is offline
post #2 of 5 Old 01-16-2008, 03:48 PM
nic2fast's Avatar
read your codes first, that is going to be your best lead. Cps is possible
99 F350 4x4 Crew Cab Duelly Flatbed
Automatic w John woods VB and HD converter
4:88 gears
Leveling kit
460,000 miles on truck 130k on motor
22.5 Peterbuilt wheels with 36" tires
Dp-tuner Chip
Gauges
4in Turbo Back Silverline Exh. into grand rock 6" mitercut stacks
Irate Diesel S366 turbo kit
Full Force diesel Stage 1 Injectors
DIY Intake
Terminator modded HPOP
Irate Diesel comp. fuel system with RR
Iron Bull Front Bumper with 12,5 winch
Reacon smoked cab lights and LED bed lights
nic2fast is offline
post #3 of 5 Old 01-17-2008, 04:43 AM Thread Starter
Replaced CPS, no luck. Does a little better but still no luck. I get the check engine light when the engine is under somewhat heavy throttle. Once it comes on, it stays on until i turn the ignition off and crank back up. After that it does fine until i give it heavy throttle. That is the cycle. I'm gonna check the codes today or tomorrow, borrowed a jeep until then. I'll let ya'll know what i find. thanks.
post #4 of 5 Old 01-18-2008, 11:00 AM Thread Starter
Went to autozone to check codes, no luck. No codes, probably not a compatible scanner. Anyone have anymore suggestions? I been told to check the check valve on the HPOP. Not sure if this is a fix or not. My situation happens during acceleration. Could it be a MAP sensor or exhaust backpressure sensor? Has anyone had this problem and found a solution?
post #5 of 5 Old 01-18-2008, 06:37 PM
nic2fast's Avatar
Don't think it is the check valve because my understanding is that the check valve holds oil in the hpop pump when the engine is off, doesn't effect the engine when it is running. It's more less an anti-drain back valve. Your right on the scanner, autozone and Advance do not have scanners that can read diesel trucks. Gonna have to get a mech. to read it for you. Might cost a little but better than throwing money away on non needed items.
4:88 gears
Leveling kit
Dp-tuner Chip
Gauges
DIY Intake
nic2fast is offline
