low oil pressure please help - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-12-2013, 10:56 AM Thread Starter
hello i have a 1999 f350 7.3l with ts 6 position chip it has 245,000 miles recently started running and idleing really rough noticed the oil pressure gauge shows 0 we have replaced the ipr valve and the icp no help smoothes out at higher rpm hard starting and shakes whats next to check and info would be great also changed oil because there was fuel in it but no help either
dohertypropertymaint is offline
post #2 of 6 Old 03-12-2013, 11:59 AM
timmyboy76's Avatar
if you got fuel in your oil, you need to check orings on injectors. Might as well, buy thee entire kit to replace all the orings.
Going on a limb here, but if oring/s are bad, then i can see how the lpop cant create pressure..(low oil pressure), with a shot oring, or the lpop itself is just bad too. Melling 208 is what they replace them with....but fuel in oil, you need to find the culprit.
99.5 x-cab 7.3l, 6spd, 161k miles.....
timmyboy76 is offline
post #3 of 6 Old 03-12-2013, 12:33 PM Thread Starter
Do I need any special tools to remove injectors and is there a way to tell which one may be bad before I pull them
post #4 of 6 Old 03-12-2013, 09:51 PM
Powerstroke Techie
Quoted: 337 Post(s)
if the truck is running and your oil pressure gauge is not registering, the gauge is inaccurate. either due to the sender, gauge, or wiring.
check your codes and report back
the richest ones are not those who have the most, but those who need the least
kaya is online now
post #5 of 6 Old 03-13-2013, 05:39 AM Thread Starter
Yes I figured the gauge is ring because if there was truly no oil pressure then the truck would. Not run but still runs very rough but no blue or white smoke
post #6 of 6 Old 03-13-2013, 08:35 PM
Powerstroke Techie
Quoted: 337 Post(s)
have you checked for codes?
kaya is online now
