2001 F250 IDM Location ?? and more
HI
can someone help me out here , I cannot find The IDM they said its by the drivers side front fender but I can't find it , having trouble with this truck , bought it with a bad motor rebuilt it new pistons and everything and having a starting problem this sucks, I put new PCM in it new valve cover gaskets and wire harness ccouple new sending units and still barely starts with help from wd40, either or whatever,next I'm going to try new injectors I guess, maybe it's bleeding down and gettting air in it I'm ready to CRACK ,when it does start it runs ruff for a little while then runs perfect and you can drive it and it's great ,let it sit for more than 6 hrs your back to square one no start tries to but dont ANY idea's please thanks Kevin |
after it sits for a while. take the small hex plug out of the top of the hpop resivore you should see oil to the bottom of the hole if not the check valve is letting the resivore leak down.
yep check that and oil is to the bottom of the threads, does anyone know where the IDM is located ??? I put new glow plugs in it and a new GP relay the fuel pump sounds like its working check the filter any other sugestions would be great
and that check valve you were talking about wheres that located in that hpop
You access the IDM through the driver's side wheel well. You have to remove part of the inner fender to get to it.
well thats helps alot been driving me crazy trying to find it thank you
